5/16 cove and bead bit - Router Forums
post #1 of 5 (permalink) Old 07-30-2018, 08:12 PM Thread Starter
Default 5/16 cove and bead bit
Hello,
Wondering if anyone knows of a source for a 5/16 radius cove and bead plunge/grove bit? I have found that most manufacturers only go up to 1/4 inch radius which is too small for the project I am planning.
Thanks,
Dan.
danletkeman is offline
post #2 of 5 (permalink) Old 07-30-2018, 08:35 PM
Semipro's Avatar
First Name: John_*
Is this what your looking for
54104 Carbide Tipped Classical Bead & Cove 13/64 x 5/16 Radius x 1-1/4 Dia x 1/2 x 1/2 Inch Shank
https://www.amazon.com/Amana-Tool-Ca.../dp/B000P4SEVS
Semipro is online now
post #3 of 5 (permalink) Old 07-30-2018, 09:13 PM
Not in a plunge type. You could cut the bearing off one but it wouldn't plunge. You'd need a starter hole or straight groove and then plunge into that. Part of the problem for that is that the size it needs to be for that radius makes it so big that it might be dangerous to plunge. When you start getting up around 2" diameter most of the makers put a disclaimer in the package saying it should only be used in a router table which means you don't plunge it.
post #4 of 5 (permalink) Old 07-31-2018, 02:16 AM
TWheels's Avatar
Originally Posted by danletkeman View Post
Hello,
Thanks,
Dan.
From what I can find 5/16 is an unusual radius. Would 3/8 inch radius work?
Would itn be possible to provide a drawing or picture of what you need or the project?
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 5 (permalink) Old 07-31-2018, 07:58 PM Thread Starter
I would like to have one without a bearing. I want to use it at a 45 degree angle to the work piece in order to cut a cove and bead in the face of the stock. Simply put, use a 45 degree fence on the router table.
I did eventually find one sold by magnate that I think I am going to try.
https://www.magnate.net/ProductDetai...=3935&CartID=1
1/4 inch cove and bead bit ExpressEN1 General Routing 7 01-19-2015 08:04 PM
cove bead salukiraptor Router Bits - Types and Usage 5 08-22-2014 10:20 PM
large-ish (0.5" - 1" radius) bead & cove / flute and bead bits carl0s Router Bits - Types and Usage 8 01-07-2013 10:11 AM
Cove and Bead cutters ? Steve. B. New Member Introductions 1 01-26-2008 02:43 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
