Why is my plywood fraying on the edges - Router Forums
 3Likes
post #1 of 12 (permalink) Old 08-01-2018, 01:10 PM Thread Starter
Default Why is my plywood fraying on the edges
I’ve tried several different downcut bits to cut monograms out of birch plywood with my CNC machine. But the edges always come out so frayed. What bit can I use to stop it from fraying? Is there such a bit? It takes me forever to sand each monogram after I cut it and it’s almost not even worth my time!
Kirstmccall is offline
post #2 of 12 (permalink) Old 08-01-2018, 01:19 PM
welcome to the forums N/A..
what brand of bit are you using??
have you cleaned it recently and is it sharp???
post #3 of 12 (permalink) Old 08-01-2018, 01:24 PM Thread Starter
Yes, if does this with brand new bits too! I have used a spiral downcut but, a straight flute bit and another type of downcut bit! Would an upcut but work better? They are just hard to find! No one local sells upcut bits
post #4 of 12 (permalink) Old 08-01-2018, 01:24 PM
Nickp's Avatar
First Name: Nick
Welcome...you will get some good advice I'm sure...
In the meantime...feed rate, bit speed, depth of cut, direction of cut could affect quality...
Is the cutting side of bit fraying or trailing edge...?
Is the cut width you desire the same size as bit...? Maybe a smaller bit with direction change on second pass...?
Again, welcome...lots of talent here...
Roy Drake likes this.
Nick
Nickp is offline
post #5 of 12 (permalink) Old 08-01-2018, 02:02 PM
where are you???
you need to fill out your profile...
we work better w/ more information...
post #6 of 12 (permalink) Old 08-01-2018, 03:28 PM
Have you considered using a synthetic material? All told it may be cheaper in the long run. Any time you cut across the grain you are likely to have problems. One other idea. Are you taking a very light finish cut(or maybe two)?
post #7 of 12 (permalink) Old 08-02-2018, 06:19 AM
First Name: Larry
Welcome to the forum N/a
Knot working is offline
post #8 of 12 (permalink) Old 08-02-2018, 06:57 AM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute complete your profile with first name and location.
The only plywood I cut is 1/2" Baltic Birch and most of the time I use a 1/4" downcut spiral 2-flute bit. The edges come out clean. Are you cutting too much in one pass, possibly? I take a roughing pass and then come back with a final pass to remove the last 0.005". I do the same thing when I engrave with a V-bit, too.
This is the only photo I have of a freshly cut piece and you can see the edges are pretty clean.
Why is my plywood fraying on the edges-018-16-inch-longworth-chuck-long-slots-cnc.jpg
David
PS - I'm using a Whiteside 1/4" spiral downcut bit but they also have it in upcut. Matter of fact, I have both upcut and downcut in 1/8", as well.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #9 of 12 (permalink) Old 08-02-2018, 07:37 AM
First Name: mary
I use a freud 75-103 up sprial bit for most cut out letters. Never had a problem unless the bit is not sharp.
marecat3 is offline
post #10 of 12 (permalink) Old 08-02-2018, 09:22 AM
MEBCWD's Avatar
Welcome to the Router Forums.
I have a few questions.
Do you have any pictures of your machine and of the cut left when cutting the plywood? You can post pictures that are on your computer.
Is this new plywood or has it been stored for a while where it might have been subjected to heat or moisture? How thick is the plywood?
What size bit are you using? Is your feed rate, spindle speed and depth of cut correct for the bit, material and machine?
What kind of CNC machine do you have? Homemade MDF, DIY kit, plug and play hobby machine or something else? Is there any looseness in the machine and if so can it be adjusted to tighten up the machine?
Do you have a spindle or a router? Could the mount be loose? Have you checked the collet for runout? Are the bearings good or could they be causing runout?
It does help when you fill out your profile with the tools and other information about your shop.
MEBCWD is offline
How to best dress up the edges on Rockler table top? xvimbi Table-mounted Routing 2 08-06-2010 02:39 PM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Finishing exposed plywood edges wthomaz General Routing 9 11-11-2009 01:43 AM
Routing Plywood Edges beemerbob Table-mounted Routing 1 12-16-2006 04:04 PM
