Is there one bit or two - Router Forums
 3Likes
post #1 of 17 (permalink) Old 08-12-2018, 02:24 PM Thread Starter
First Name: Wayne
Red face Is there one bit or two
Hello, I'm a new comer to your forum with a few questions. I have been trying to figure out if the lath on the top of a wall clock I am putting with is made with one bit or two. I have several folks I know that do woodworking and no one has given me an answer. My router will only handle 1/4" shaft bits.
I found your forum by accident, but I think I'm glad I did. Thank you for any help you provide.
Wayne
Sawdust68 is offline
post #2 of 17 (permalink) Old 08-12-2018, 02:43 PM
welcome to the forums Wayne...
the answer is both... plus one..
1 single cove bit done in 2 cuts...
the small cove is cut 1st..
the piece is flipped end for end and rotated on it's long axis 90° for the 2nd cut...
and then finished w/ the plus one bit...
or a single profiled bit was used.. and there are many...
all ya gotta do is find it...
plus another one of course..
or 2 bits.. plus one
1 each cove bit and one each core box bit or ball end bit...
the plus one is a round over bit for the light edge radius...
here.. look this PDF over and you'll get the idea......
post #3 of 17 (permalink) Old 08-12-2018, 02:48 PM
now you might as well jump in and take on the whole set of PDF's...
Just go to this link.....
post #4 of 17 (permalink) Old 08-12-2018, 03:43 PM
Some furniture manufacturers would have the bit made for them if they were doing a production run using that molding but it can easily be done in two passes. It's hard to tell if both curves are the same radius. If they are you only need one bit. If they are different then you need two. Those profiles are some of the cheapest bits you can buy. If you should get lucky and find a bit that will do both curves at once it won't be cheap. It would be considered an architectural molding bit and likely run you $100 plus.
There are two types of profiles that will make those curves. One is cove bits which usually are guided by an integral bearing. The other is round nose bits which you need an edge guide for or to use them in a router table with fence.
post #5 of 17 (permalink) Old 08-12-2018, 04:01 PM
and don't forget the round over...
size the radii from the middle of the molding and not the end..
fuzzies are your option..
post #6 of 17 (permalink) Old 08-12-2018, 05:59 PM
I usually sand or scrape round overs that small. Usually that's faster that getting a bit set up and normally you have to sand a little after anyway.
post #7 of 17 (permalink) Old 08-12-2018, 06:15 PM Thread Starter
First Name: Wayne
Thank you gentlemen for getting back to me. I must admit that Stick you had me a bit confused with the 2 plus one, but I believe I understand. Sorry the pictures were a bit sideways. On my computer they were ok. And I think I'll leave the fuzzies off the final product. Take care and be careful. Wayne
post #8 of 17 (permalink) Old 08-12-2018, 06:30 PM
Wayne...
in the 3rd picture I'd be WTB that a small crown molding...
post #9 of 17 (permalink) Old 08-12-2018, 06:35 PM
Here are some of the bits used to make those profiles...
post #10 of 17 (permalink) Old 08-13-2018, 06:54 AM
First Name: Larry
Welcome to the forum Wayne.
Knot working is offline
spiral bit for cutting plywood calneva Router Bits - Types and Usage 11 09-28-2017 06:25 PM
Glue Joint Router bit Setup on stock pooch692000 Router Bits - Types and Usage 5 12-02-2016 05:32 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
