Sliding door bottom guide groove - Router Forums
 7Likes
post #1 of 12 (permalink) Old 08-21-2018, 10:49 AM Thread Starter
Default Sliding door bottom guide groove
I am installing a pocket door. One option for the bottom door guide (keeps the bottom of the door stable when sliding open/close) is to cut a groove 5/16” wide by 1” deep on the bottom of the door. The groove will need to be straight and on center of the 1-3/8” thick door. I am searching for a bit that will allow me to lay the door horizontally on saw horses and run the router vertically along the bottom of the door. Does anyone know of a bit that will allow me to do this? My other option is to make a jig to use a 5/16” mortise bit. But, I prefer just to use the router. Thanks!
Busdriver1969 is offline
post #2 of 12 (permalink) Old 08-21-2018, 12:36 PM
welcome N/A...
A slot cutter is what you are looking for...
Stick486 is offline
post #3 of 12 (permalink) Old 08-21-2018, 03:50 PM
Busdriver; Hi, and welcome!
Re the pocket door guide system, you have thought of the fact you'll have an upstanding fin on the floor which will be vulnerable to damage as well as a tripping hazard?
Any pocket doors that I've installed have had a guide that fitted on the face of the pocket, or in the case of large openings, aluminum extrusions which featured threshold 'ramps' on either side of the door.
Pretty sure I've never used the fin thing except on a wall cupboard(?)....
https://www.google.com/search?q=pock...ih=769&dpr=1.2
DaninVan is offline
post #4 of 12 (permalink) Old 08-21-2018, 05:23 PM
the fin is used at the bottom of the frame.. not in the pass way...
the guides you are talking about mar the door after awhile..
harrysin likes this.
Stick486 is offline
post #5 of 12 (permalink) Old 08-21-2018, 07:16 PM
5/16" x 1" seems pretty serious for the add-on fin style(?)...
Re the door frame guides; they're not really supposed to rub on the door face, bottom edge yes. There's also the roller style of guide.
DaninVan is offline
post #6 of 12 (permalink) Old 08-21-2018, 07:36 PM
but they do rub...
I thought 5/16 was pretty big too..
3/16~1/4'' is the usual...
Stick486 is offline
post #7 of 12 (permalink) Old 08-21-2018, 08:20 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #8 of 12 (permalink) Old 08-21-2018, 08:22 PM
If the door when closed has an inch or so of the edge still inside the frame, then there won't be any wear and tear on the groove or the door's bottom edges, the door will still be in contact with the guide--unless there are teen agers around. I think I'd want to use some aluminum for the guide so I never had to replace it. And I'd round over the edges near the pocket opening to keep a squared leading edge from eventually tearing up the groove. Repairing a pocket door inside the pocket doesn't sound like much fun.
If this is for a bathroom, you might want to make sure there's a lock on it. I don't like the indents on the door, I always catch my finger in it--ouch.
DaninVan likes this.
post #9 of 12 (permalink) Old 08-21-2018, 08:45 PM
With the slight cant to the guides they shouldn't really touch the door skins.
https://www.amazon.ca/Slide-Co-16193...+door+hardware
DaninVan is offline
post #10 of 12 (permalink) Old 08-22-2018, 06:45 AM
First Name: Larry
Welcome to the forum N/a
Knot working is offline
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
Craftex Sliding Table Saw Attachment CX200S CanuckGal Tool Reviews 6 07-02-2012 10:19 AM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 01:36 PM
two groove dovetail sliding lid, how to? Wooden Starting Off 6 12-07-2011 06:13 AM
