Box Joint Router Bit - Page 2 - Router Forums
 21Likes
post #11 of 19 (permalink) Old 10-10-2018, 04:46 PM
TS here too...
Gene Howe likes this.
post #12 of 19 (permalink) Old 10-10-2018, 09:07 PM
TWheels's Avatar
Fred...
CMT...
Whiteside...
MCLS is junk...
Sommerfeld https://sommerfeldtools.com/professi...nger-joint-bit
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #13 of 19 (permalink) Old 10-11-2018, 12:00 AM
TWheels's Avatar
Originally Posted by hawkeye10 View Post
Jim, I use a regular 1/4" bit to do mine on the router table. I quit doing it on the router table because I was getting blow out from the router bit. You will do better with a box joint TS blade. As far as I know, there is no such thing as a box joint router bit.
https://www.amazon.com/Freud-20T-Joi...int+cutter+set
Is there any advantage to the blade referenced by @hawkeye10 over the more general dado blade, aside from the $15 lower price? https://www.amazon.com/dp/B072MJ2V9J...9232596&sr=8-6
Also, there are box joint router bits but they do indeed have maximum cutting heights in the 35 mm (1 3/8 inch) range. For example, in addition to the bit referenced by @sunnybob , of brands at least sometimes aproved by @Stick486 , Amana: https://www.toolstoday.com/box-joint-set.html
post #14 of 19 (permalink) Old 10-11-2018, 12:27 AM
TWheels's Avatar
Originally Posted by TWheels View Post
Please note @TWheels had not read carefully enough. The Summerfeld bit is a very fine Finger joint bit, not a box joint bit
post #15 of 19 (permalink) Old 10-11-2018, 12:51 AM
1... Is there any advantage to the blade referenced by @hawkeye10 over the more general dado blade,
2... Also, there are box joint router bits but they do indeed have maximum cutting heights in the 35 mm (1 3/8 inch) range. For example, in addition to the bit referenced by @sunnybob ,
3... of brands at least sometimes approved by @Stick486 , Amana: https://www.toolstoday.com/box-joint-set.html
1... not all beasts are created equal... this is Freud's box joint blade.. much finer/cleaner cut than a dado...
Saw Blades | Dado Sets | Box Joint Cutter Set
2... lets not confuse finger and box joint bits... THEY ARE ENTIRELY TWO DIFFERENT TYPES OF JOINTS and NOT INTERCHANGEABLE NOMENCLATURE....
BOX...
FINGER...
https://www.toolstoday.com/finger-jo...outer-bit.html
3... Ahhhhh.
Amana made in Israel (very good bits) is worlds different from the Amana made in china junk...
but...
their CS leaves a lot to be desired...
4... Box joint bits do have their place... small boxes as in jewelry boxes and such...
you want big box joints.. go w/ the box blade set...
post #16 of 19 (permalink) Old 10-11-2018, 01:15 AM
TWheels's Avatar
BOX...
FINGER...
3... Ahhhhh.
but...
Thanks @Stick486
I agree with your comment about Amana CS
So Is there a reason to have both blades?
We must always keep this point in mind when considering small fingered joints. Box joints have straight boxy fingers. Finger joints have tapered fingers.
post #17 of 19 (permalink) Old 10-11-2018, 01:29 AM
yes...
they are designed to do different cuts...
the box blade give you a finished product and the dado blade cuts may need clean up...
but then again.. we all crave a set of Veritas shoulder planes..
Veritas® Small Shoulder Plane - Lee Valley Tools
Veritas® Miniature Shoulder Plane - Lee Valley Tools
study the tech and capacities...
Saw Blades | Dado Sets | Pro Dado Sets
jj777746 likes this.
post #18 of 19 (permalink) Old 10-11-2018, 09:48 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I've only made a couple of boxes using this bit which was very cheap on Ebay and it worked well after working on it to make it precision. It restricts the height of the box of course hence only two boxes.
Name:	box joint cutter0001.jpg
Harry
harrysin is offline
post #19 of 19 (permalink) Old 10-11-2018, 10:59 AM
I keep coming back to the Incra I-box jig and the Freud 1/4-3/8ths blade for general use. For larger fingers, I just use my dado set. The Incra jig adjusts for whatever dado stack I choose and cuts perfect fitting joints. The router bit approach is far less than the $164 jig, and if you add the Bosch blades and/or decent 8 inch dado set, the cost is significant.
If cost is an issue, then a quality, sharp, clean router bit, plus a little cleanup and using entry and exit sacrificial pieces works OK, so long as there's no chipping to ruin the piece.
But there's no question that the Incra I-box jig is a great solution for freuent box makers, or anyone who wants to make a long box joint on larger sized projects.
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
For Sale: Whiteside 3390 Fine Finger Joint Router Bit jvg2259 Woodworking Classifieds 4 07-02-2015 09:31 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
How to setup a Finger Joint Assembly Router Bit Bychen Router Bits - Types and Usage 14 12-19-2009 02:18 PM
