Box Joint Router Bit - Router Forums
 21Likes
post #1 of 19 (permalink) Old 10-07-2018, 08:26 AM Thread Starter
Default Box Joint Router Bit
Hello all,
I am in the market for a box joint router bit to join the sides of small boxes. A couple years ago I bought a Whiteside finger joint Bit, but after one test cut, I realized that it was not what I needed. It was meant to rout a joint to either widen or lengthen two boards.
I had to sell it at a major loss, as I could not return because of it being used for test cuts.
I now want to purchase what I initially wanted, but don’t want to make the same mistake twice. So I want a BOX JOINT BIT and not a FINGER JOINT BIT.
Do any of you have a recommendation of a quality box joint bit, that is easy to setup and use.
I have seen where some of them are adjustable. Would that be difficult to use, or should I buy a fixed, say 1/8” or 1/4” joints?
Thanks for any guidance or direction that you might offer.
Sent from my iPhone using Tapatalk
Jim Gallo is offline
post #2 of 19 (permalink) Old 10-07-2018, 09:18 AM
hawkeye10's Avatar
First Name: Don
Jim, I use a regular 1/4" bit to do mine on the router table. I quit doing it on the router table because I was getting blow out from the router bit. You will do better with a box joint TS blade. As far as I know, there is no such thing as a box joint router bit.
https://www.amazon.com/Freud-20T-Joi...int+cutter+set
Herb Stoops and Jim Gallo like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 19 (permalink) Old 10-07-2018, 09:36 AM
I agree with using the table saw. With a router bit you can get blowout on both front and back (opposing corners) requiring backer boards on both sides. With the TS you just need one on the back side and it stays fixed with miter gauge or jig cantered on the saw blade meaning you can use it over again.
You are at least the second person who made the mistake of buying the wrong bit. If we stayed with old terminology that bit would have been called a splice bit as that is the only job it’s good for.
post #4 of 19 (permalink) Old 10-07-2018, 10:10 AM
Gene Howe's Avatar
First Name: Gene
You are at least the second person who made the mistake of buying the wrong bit..
Make that three people.
Agree that the Freud set of box joint cutters is the way to go.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 19 (permalink) Old 10-07-2018, 10:18 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
These shots show my first home made box joint jig and my current one made by OakPark, no loner in business.I often use a spiral bit but and straight bit the same size as the jig is just fine. The box joint is easy to rout, looks good and is very strong.
Harry
harrysin is offline
post #6 of 19 (permalink) Old 10-07-2018, 11:37 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
well, at least you now know the difference between finger and box joints (something MANY people do not!)
If youre making small boxes you want one of these, which for some bizarre reason, is sold as a comb joint set.
https://www.trenddirectuk.com/876x1-2tc
But that only cuts 40 mm high. With a bit of jiggery pokery you can double it up to 80 mm. But if you want bigger, than you will have to cut each slot individually.
TenGees and Jim Gallo like this.
sunnybob is offline
post #7 of 19 (permalink) Old 10-07-2018, 05:12 PM Thread Starter
Yes SunnyBob, that is exactly what I’m talking about. I have mad plenty of boxes with my shop built box Joint jigs, however, now I want to purchase a bit like the one that you linked. Was just wanting some input on the different brands, Frued, MLCS, CMT, etc, adjustable or not, ease of setup etc.
thanks.
post #8 of 19 (permalink) Old 10-07-2018, 05:46 PM
Fred...
CMT...
Whiteside...
MCLS is junk...
Jim Gallo likes this.
post #9 of 19 (permalink) Old 10-10-2018, 03:28 PM
CharleyL's Avatar
First Name: Charley
I too have tried doing box joints on my router table and I wasn't very happy with the result. There was just too much tear-out of the edges of the pins even when using backers on both sides of the work. A sacrificial backer strip is needed for both sides of the piece being cut with a router bit to reduce tear-out, because the rotating router bit cuts in both directions as it goes through the work.
I now use my table saw with a Freud SBOX8 blade set for 1/4 or 3/8" box joints and an Incra I-Box jig and get perfect box joints almost every time. I threw away all of my shop made wooden box joint jigs after buying the I-Box jig, because it's so easy to set up and use for any box joint size from 1/8" to over 3/4". It has a single sacrificial strip installed in it to reduce tear-out, but the strip only works on the exit side of the cutter, be it on a router bit or saw blade. The I-Box jig is usable on either a router table or table saw if it has a 3/4 X 3/8 miter slot, and I quickly learned that it does a much better job on the table saw with the blade sets that I'm mentioning. I also use a Freud LM72R008 1/8" ripping blade (actually 0.126" tooth width) to cut 1/8" pox joints. This blade has the flat tooth geometry that's needed to cut nice square 1/8" box joints and it works very well with the I-Box jig, if 1/8" box joints are desired. I have also used my Freud SD608 Dial A Width stacked dado blade set for 3/4" box joints, and it works, although the cuts weren't as perfectly flat bottomed, but this seems to be less visible in larger box joints.
Charley
Herb Stoops likes this.
Central North Carolina
CharleyL is offline
post #10 of 19 (permalink) Old 10-10-2018, 04:44 PM
I too use the TS for Box Joints with the Freud box cutter,or my Dado set I had resharpened to make flat cuts.
Herb Stoops is online now
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
For Sale: Whiteside 3390 Fine Finger Joint Router Bit jvg2259 Woodworking Classifieds 4 07-02-2015 09:31 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
How to setup a Finger Joint Assembly Router Bit Bychen Router Bits - Types and Usage 14 12-19-2009 02:18 PM
