Best Router Cutter To Use For Edge Jointing On Table - Router Forums
 2Likes
  • 1 Post By Stick486
  • 1 Post By TenGees
post #1 of 8 (permalink) Old 10-22-2018, 07:03 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Best Router Cutter To Use For Edge Jointing On Table
I have some boards, 45mm thick Lime and Tulipwood that I'd like to edge joint on the router table. I Googled briefly but thought quicker and best to ask here, the experts, straight from the horses mouth
I say 45mm thick, what is the practical limit in thickness one can edge joint on the router table?
Diameter of bit, spiral, etc for best finish? I need to offset the tables outfeed fence, more info on this technique please?
Thank you.
Gaia is offline
post #2 of 8 (permalink) Old 10-22-2018, 07:46 AM
you stop using the table when the boards become unwieldy or dangerous..
how long are the boards..
how wide..
what kind of joint do you want.....
butt...
splined..
finger...
glue...
lock miter...
ship lap..
biscuit...
doweled...
me ..
I spline my edges...
most excellent results for decades...
FWIW.. we understand 45mm as 7/4 S2S over here....
post #3 of 8 (permalink) Old 10-22-2018, 08:40 AM
You might be better off clamping a straightedge to the boards and following that if they are very long. Any straight but will work. I would use at least a 3/4”- 19 or 20 mm.
post #4 of 8 (permalink) Old 10-22-2018, 05:00 PM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
post #5 of 8 (permalink) Old 10-23-2018, 09:18 AM
First Name: Art
Before you invest time and money into the router bit try using a good saw blade and see what the fit looks like. I rarely use my jointer any more, I find that the table saw works perfectly fine for edge gluing. For narrower boards I simply put them on edge and run them through the planner.
mgmine is offline
post #6 of 8 (permalink) Old 10-23-2018, 09:21 AM
a straight edge and a panel bit to true the one edge abd the a glue line in the TS to parallel the second edge..
DesertRatTom likes this.
post #7 of 8 (permalink) Old 10-23-2018, 11:16 AM
TenGees's Avatar
First Name: Paul
I did a lot of this to clean the edge of plexi. If you take off very little, an ordinary straight bit works fine, not sure if a spiral may be better.
Offset your fence. Put a straight edge on the offset side. Line the fence up to the bit.
I guess the size limit would be the bit's cutting length as long as you're taking off very little.
The offset in the drawing is very exaggerated. Maybe use playing card spacers if you have adjustable faces on your fence. The adjustment of the fence is critical or you'll get snipe at the end of the cut. Test on a scrap first.
Danman1957 likes this.
TenGees is offline
post #8 of 8 (permalink) Old 10-23-2018, 01:45 PM
JOAT's Avatar
First Name: Theo
A lof of my projects have a side I want straight, so tack a straightedge down, use a flush trim bit, and viola, just want I wanted. And then almost always need a straight side angling off the first, so nail the straightedge down again. Nothing very long, but works very well for me. Oh yes, that is only when making my masters, once they are done tack that down and rout around it - clones a perfect copy every time.
JOAT is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 07:41 PM
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 12:50 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 07:43 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
