Need longer 1/4" spiral upcut bit - Page 2 - Router Forums
 3Likes
post #11 of 14 (permalink) Old 12-30-2018, 07:49 PM Thread Starter
First Name: Lenny
It's not so much the depth of cut, as you only want to remove a little With each pass, but having the extra length on the shank would be very helpful.
We have a mortiser at work but I want to work with what I have at home.
We recently had to do a bread board edge on a custom table that required deep mortises beyond the 6 1/2" capacity of our mortiser. Drill press and chisel work.
toolmanlh is offline
post #12 of 14 (permalink) Old 12-30-2018, 08:18 PM
Not cheap but if you are looking for a deep mortiser here's one: https://www.amazon.ca/Makita-7104L-1...SIN=B0002HC2VQ These are mostly for log house building so you would probably want to clean the sides up with a chisel.
post #13 of 14 (permalink) Old 12-31-2018, 06:43 AM Thread Starter
First Name: Lenny
In the past I have used our lock mortiser for deep mortises and it worked great. But again, you are limited on size of bits. It just seems like there is a real limitation for deep 1/4" mortises with a router.
post #14 of 14 (permalink) Old 12-31-2018, 12:37 PM
One of the other ways to do the breadboard end would be to make a sandwich instead of using a piece of solid wood on the end. You could make it interesting by using a different colored wood for the core than the top and bottom pieces which would also hide the glue joint. Change the problem into a "design opportunity" as Harry likes to call his work arounds when things don't go as planned.
STUCK BIT -- Bosch 1604A stuck with a 1/4" shank junky roundover bit corbind General Routing 27 02-24-2014 08:51 AM
upcut vs downcut spiral Skyewalker Router Bits - Types and Usage 7 09-10-2012 06:00 AM
Spiral bit help Ken Bee Router Bits - Types and Usage 6 01-01-2012 02:34 PM
Using a 1/4" bearingless bit on a template ShawnF Guide Bushings and Templates 1 10-05-2011 12:04 AM
Why the difference in 1/4" spiral upcut bits? Skyglider Router Bits - Types and Usage 7 12-14-2008 06:41 PM
