lock miter bit...again - Page 2 - Router Forums
 11Likes
post #11 of 25 (permalink) Old 01-22-2019, 09:33 AM Thread Starter
sreilly's Avatar
First Name: Steve
Originally Posted by harrysin View Post
Wouldn't it be more accurate to do that on the router table?
I hadn't seen this when I replied to Biagio and now I have a picture to boot. Thanks Harry. Seriously, sometimes I really do need it spelled out and a picture never hurts......
sreilly is offline
post #12 of 25 (permalink) Old 01-22-2019, 09:59 AM
more practical, cheaper, faster and easier on the TS...
post #13 of 25 (permalink) Old 01-22-2019, 10:37 AM
Honored Member
harrysin's Avatar
First Name: Harry
What about accuracy Stick, a router bit is accurate and NON-ADJUSTABLE, a table saw is adjustable and therefor can be a whisker out.
Harry
harrysin is offline
post #14 of 25 (permalink) Old 01-22-2019, 10:53 AM
all you are doing is hogging away material giving the lock miter bit less to cut..
post #15 of 25 (permalink) Old 01-22-2019, 11:10 AM
Use a Wixey digital angle gauge to set the blade at 45 degrees. Use a full kerf blade. Can't get more accurate than that.
post #16 of 25 (permalink) Old 01-22-2019, 11:28 AM
I posted this picture a couple of days ago, but in the wrong place. The pix if of the Infinity lock miter jig. Find a safe place to store these in a container, they are easily misplaced. The magnets hold them in place. Those are Infinity bits.
Name:	Increa lock miter jig I have these.jpg
post #17 of 25 (permalink) Old 01-22-2019, 05:35 PM
Country: South Africa
First Name: Biagio
Harry, I’m with Stick on this. Removing the excess stock does not require infinite accuracy - that will be supplied by the lock mitre bit itself. Using a 90 degree V bit will still mean pulverizing all the wood below the diagonal. Easier and quicker with a saw, especially if doing long boards.
Biagio is offline
post #18 of 25 (permalink) Old 01-23-2019, 09:22 AM
Honored Member
harrysin's Avatar
First Name: Harry
I tried the saw once and it didn't leave a perfect point which meant that the lock mitre wasn't perfect so I have never used the saw again for this purpose.
Harry
harrysin is offline
post #19 of 25 (permalink) Old 01-23-2019, 09:45 AM
perfect point... once...
do you mean toe???
if so, you took off too much...
try it again Harry..
post #20 of 25 (permalink) Old 01-24-2019, 09:12 AM
Honored Member
harrysin's Avatar
First Name: Harry
Why should I take a chance when I have a perfect method. In any case you prove my point that because the saw is adjustable, it's possible for the average amateur to be a touch out, but not with my method!
Harry
harrysin is offline
Lock Miter Bit pusserboy General Routing 19 05-28-2018 10:19 AM
What lock miter bit would you recommend? adot45 Router Bits - Types and Usage 15 01-25-2015 10:26 AM
Lock mitre router bit - custom angles radiohead Router Bits - Types and Usage 15 11-01-2013 02:14 PM
Has anyone used a lock miter bit? dustmaster Router Bits - Types and Usage 29 01-30-2011 07:53 AM
Lock miter bit for 3/8' pine lpret Router Bits - Types and Usage 8 04-28-2010 10:31 AM
