lock miter bit...again - Router Forums
 11Likes
post #1 of 25 (permalink) Old 01-21-2019, 02:42 PM Thread Starter
sreilly's Avatar
First Name: Steve
Default lock miter bit...again
So I finally found a source for Baltic Birch plywood in 1/2" and 3/4" but they're in 5'x5' sheets. So layout will take more thought as I'm used to 4'x8' sheets. But I digress, what I'm mostly interested in is how well the lock miter bit will work on 1/2 Baltic plywood. I tried it on the box store's plywood and it was disastrous. The tear out was horrible all along the cut but I'm wondering if it was because of the quality of the plywood. I also have both the 1/2" and 3/4" Infinity Tools Lapped Miter Joint Router Bit which I suspect may work well on plywood drawers? Any feedback on if Baltic plywood will yield better results and if the Lapped Miter Joint Router Bit might be a good choice as well?
If this works well I may try my hand at using some Baltic Birch on the PC dovetail jig.
sreilly is offline
post #2 of 25 (permalink) Old 01-21-2019, 03:11 PM
you should find it to work quite well...
Stick486 is offline
post #3 of 25 (permalink) Old 01-21-2019, 03:33 PM
Baltic Birch IS ply wood, so is Apple Ply. The other stuff ranges from horrible to just barely passable. Worst of all is the Chinese stuff that is filled in with fine strips of splinter causing bamboo.
Your joint should look pretty nice. Use a backer board of some sort at the exit end of the cut to help avoid tear out. I generally use a chunk of MDF for a push block/backer board.
harrysin and MEBCWD like this.
post #4 of 25 (permalink) Old 01-21-2019, 04:12 PM Thread Starter
sreilly's Avatar
First Name: Steve
Thanks guys. This will be my first try with Baltic, that's once I get there to pick some up, so now it's way up on my list. I'll get a few 1/2" sheets and one 3/4" to wet my feet and see how things go. I've got a built-in panty that needs to be built. Right now it's a walk-in closet with a upright freezer and a few cheap plastic self standing shelf units. I envision base cabinets with adjustable shelves above with yet again more cabinets above for the need to have but seldom used goods. It can be so much more than it is now and I promised her I would build it.....another month or two of physical therapy and then.
MEBCWD and TenGees like this.
sreilly is offline
post #5 of 25 (permalink) Old 01-21-2019, 05:36 PM
TwoSkies57's Avatar
a good portion of the work piece edge can be cut off at the table saw prior to using the bit on the router table. Extend the life of your cutting edge and save yourself some time. Create an edge on a scrap piece of work, from there you can get a good idea of how much you can remove at the tablesaw.
Skipper the Penguin
TwoSkies57 is offline
post #6 of 25 (permalink) Old 01-21-2019, 08:09 PM Thread Starter
sreilly's Avatar
First Name: Steve
Bill I don't follow what you're saying. Typically I mill my wood to the needed size and then cut the boards for the drawers to size before routing any edges. If I'm using the table saw for the bottom shelf slot I may cut that first which helps in remembering which is inside and bottom orientation.
Danman1957 likes this.
sreilly is offline
post #7 of 25 (permalink) Old 01-21-2019, 09:57 PM
hog the router cut out on the TS 1st...
Stick486 is offline
post #8 of 25 (permalink) Old 01-22-2019, 08:02 AM
Country: South Africa
First Name: Biagio
Steve what the guys are saying is that you can reduce the load on bit and router by first cutting a 45 degree bevel on your board on the saw, taking care not to cut the full thickness of the board, I.e. leaving a thin facet at the top, to ride against the router fence. Otherwise, you would be pulverizing more than the thickness of your board with the router bit (because of the hypotenuse), with all the dust that flesh is heir to.
Biagio is offline
post #9 of 25 (permalink) Old 01-22-2019, 08:27 AM
harrysin's Avatar
First Name: Harry
Wouldn't it be more accurate to do that on the router table?
Name:	mitres for John.jpg
Danman1957, TenGees and sreilly like this.
Harry
harrysin is offline
post #10 of 25 (permalink) Old 01-22-2019, 08:29 AM Thread Starter
sreilly's Avatar
First Name: Steve
OK now I get it. Sometimes I need a picture, more coffee, my meds, and then some more pictures and coffee. That makes perfect sense and I'll be sure to try that. I agree that make less aggressive cuts can only help. Thanks for spelling it out for me.
sreilly is offline
Lock Miter Bit pusserboy General Routing 19 05-28-2018 09:19 AM
What lock miter bit would you recommend? adot45 Router Bits - Types and Usage 15 01-25-2015 09:26 AM
Lock mitre router bit - custom angles radiohead Router Bits - Types and Usage 15 11-01-2013 01:14 PM
Has anyone used a lock miter bit? dustmaster Router Bits - Types and Usage 29 01-30-2011 06:53 AM
Lock miter bit for 3/8' pine lpret Router Bits - Types and Usage 8 04-28-2010 09:31 AM
