How to Use Rockler 61886 Finger Joint Bit - Router Forums
 10Likes
  • 6 Post By Nickp
  • 1 Post By gdonham1
  • 2 Post By gdonham1
  • 1 Post By Nickp
post #1 of 10 (permalink) Old 01-30-2019, 05:47 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Default How to Use Rockler 61886 Finger Joint Bit
I have a Rockler bit 61886. It is a finger joint bit but I cannot find any instructions for how to use it. I bought it a few years ago at a clearance sale at Rockler. I have a need for some finger jointed lumber and want to use it. Attached is a picture.
The puzzling thing about the bit is at the top is a square 1/4" cutter. I have not used a finger joint bit before but I thought you ran part A through the bit then used a spacer or adjusted the bit down/up and ran part B. The square cutter is used for something but I cannot figure out what. There is only the one bit and not a pair like cope and stick cabinet door bits.
If anyone knows how to use this I would appreciate the help.
gdonham1 is offline
post #2 of 10 (permalink) Old 01-30-2019, 06:16 PM
Nickp's Avatar
First Name: Nick
Couldn't find it in Rockler but Amana's bit looks exactly like yours...
it seems you would cut the first piece and the second piece is cut upside down. If the cutters are spaced properly for the size of the wood, the 1/4" cutter makes a complimentary cut on each of the pieces.
Nick
Nickp is offline
post #3 of 10 (permalink) Old 01-30-2019, 06:43 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Thanks,
I found a video on youtube.com about the Infinity Tools Finger Joint Bit. It explained that you reorganize the bits according to the height of your wood. You run one side up and then turn the second piece with the opposite face up. This is how you get the ends to match up. The nut on the top of the bit is removed and you restack the bits and do some testing and fine tuning, then run your production work.
I have a lot of reclaimed oak from a church furniture factory. A lot of it is glued up with 4/4 pieces to be seats and pew bench ends. I have resawed a lot of it and run it through the planner and got a lot of 7/8" four to six inch boards that are from 28 to 14 inches long. . I have a project to make and want to use this material to make longer boards.
Mystery solved. Thanks for your help
TenGees likes this.
gdonham1 is offline
post #4 of 10 (permalink) Old 01-30-2019, 07:18 PM
Nickp's Avatar
First Name: Nick
Excellent...good luck... @gdonham1
...have you figured how to finger joint the 4-6" boards...or another mystery...?
Maybe a different joint method...? Here's an article that might give you some other ideas... https://www.woodmagazine.com/woodwor...ery/end-to-end
After you join them, might you need strength if used horizontally...? like shelves...?
What are you making with the jointed boards...? That might drive which (or better) joint to use...
...just thinkin' out loud...
Nick
Nickp is offline
post #5 of 10 (permalink) Old 01-30-2019, 07:25 PM
move to the head of the class...
stagger the FJ's and edge spline..
post #6 of 10 (permalink) Old 01-30-2019, 11:24 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Thanks forr your replies.
The finger joints for this project will work best. I have milled the boards to 7/8" thickness. I will trim all boards to 4" wide and then finger joint them together. After I make the longer boards I will then glue two layers together and of course stagger the finger joints. I need four boards that are 4" x 52" and eight 4" X 33" and a few other pieces. So in the end I will have two 7/8" thick boards glued up and the finished dimension of the boards will be 1.75" Thick X 4" wide X 52 Long".
The reason for this is most of my lumber is reclaimed and are 12" to 24" long. The finger joints will allow me to make longer boards and laminating two of them together will work like segmented bowls, staggering the finger joints will make it very strong.
Since I have so much of this lumber I need a practical way to make longer boards. I will most likely not do any edge gluing but the finger joint bit makes that work pretty good for alignment. So if I need to make some panels I can finger joint the ends then edge joint after trimming the boards and make wide panels if required.
After I make the end grain finger joints I will run all boards through a drum sander to clean up any variations, joint one edge, then trim to a uniform width on the table saw.
Yes it is a lot of work but the project I have in mind will be worth the effort.
Thanks for your advise and help
TenGees and dirt_dobber like this.
gdonham1 is offline
post #7 of 10 (permalink) Old 01-31-2019, 06:50 AM
Nickp's Avatar
First Name: Nick
It certainly sounds like you got it all together...best success with your project...would love to see what you end up with...
Didn't mean to bombard you with all the questions...
Nick
Nickp is offline
post #8 of 10 (permalink) Old 01-31-2019, 12:45 PM
If you stagger joints then you don't really need to joint the ends like that. The double thickness lam should be strong enough for short lengths. In longer lengths or when bending lams to make ribs you have to make scarf joints which is a tapered lap. I tried making ribs for tarp covered buildings once. On 3/4" thick lumber the scarf joint had to be 9" long.
post #9 of 10 (permalink) Old 02-02-2019, 02:25 AM Thread Starter
gdonham1's Avatar
First Name: Guy
I found instructions on Infinity Tools website and for Amana. I got the bit working today. At first I rearranged the cutters so I had two of the little cutters and the big one on top. I got it to work but had a lip at top and bottom. I figured out that I needed three of the cutters and the large one and the problem was solved. You would have to rearrange the cutters for your particular thickness of wood. I had 7/8" thick. The cutter is a little picky but once I got it dialed in it went like clockwork. I used my coping sled that is usually used with cope and stick router bits. The coping sled held each piece very well and I got the height all set up and replaced the backer board and go no tearout or fuzzies. So far so good. Like many bits, 45 degree lock miter, and others, there is a lot of fussy setup. Once you get it set up things work well. It is just frustrating to get to the perfect setup.
One thing I did learn is you run one end, part A through the router, then you run the second board, part B, and place the A cut on the table and turn the B cut over and slide the two together. If part B is above part A then you move the bit down. If the opposite is true then you move the bit up. I have a Jessum FX router lift and the crank is calibrated to 164" increments.
gdonham1 is offline
post #10 of 10 (permalink) Old 02-02-2019, 06:39 AM
Nickp's Avatar
First Name: Nick
Excellent, Guy...like eating an elephant...one bite at a time...
Stick486 likes this.
Nick
Nickp is offline
Eagle America Keepsake Box Router Bit gdonham1 Router Bits - Types and Usage 1 11-20-2018 10:06 AM
For Sale: Whiteside 3390 Fine Finger Joint Bit Jim Gallo Woodworking Classifieds 20 12-15-2016 08:59 PM
Reversible Glue Joint Bit and Lock Miter bit Shells Router Bits - Types and Usage 35 03-10-2014 08:11 PM
Help With Finger or Box Joint 1x3 Wood Psychbiker General Routing 15 01-06-2014 12:17 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
