What bit for this tray? Templates - Router Forums
 10Likes
  • 2 Post By kp91
  • 2 Post By Nickp
  • 4 Post By DesertRatTom
  • 1 Post By harrysin
post #1 of 9 (permalink) Old 03-17-2019, 05:08 PM Thread Starter
Default What bit for this tray? Templates
Hello all,
Wondering if you could help me identify the proper bit for this wooden serving tray. I had a couple thoughts, but they all came up a little short.
Also, I had to create a new profile on here because the password reset link would never emailed to me. I checked spam, junk, everything. Thoughts on that, administrators?
gpstew is offline
post #2 of 9 (permalink) Old 03-17-2019, 05:27 PM
kp91's Avatar
First Name: Doug
Bowl and Tray bit
they come in a bunch of different diameters, you get the radios that you want to match. I use one carving my dog paw bowls
Lots of different kinds from a lot of different makers, check the specifications online
https://www.mlcswoodworking.com/shop..._bowltray.html
MEBCWD and sreilly like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 9 (permalink) Old 03-17-2019, 06:39 PM
Nickp's Avatar
First Name: Nick
Originally Posted by gpstew View Post
Hello all,
You might want to send a message to @Cricket ...
Cherryville Chuck and MEBCWD like this.
Nick
Nickp is offline
post #4 of 9 (permalink) Old 03-17-2019, 09:49 PM
Same recommendation Bowl and tray bit for the inside, roundover for the outside. Pix attached. Not particularly expensive. For larger bits, slow the router down. Do it on a table and you use a stop block and make several passe, a little deeper each pass. The flat bottom can be used to rout out the main body of the tray.
post #5 of 9 (permalink) Old 03-18-2019, 09:21 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Shots 21 to 25 in the first pdf shows what has been described. For your tray I would first rout it using straight bottom cutting bit followed by the dish cutter. The second pdf shows another project where I used a dish cutter.
MEBCWD likes this.
Harry
harrysin is offline
post #6 of 9 (permalink) Old 03-18-2019, 09:03 PM Thread Starter
Thanks everyone for your replies. I searched for a long time. I can't believe that I never ran across this bit. I was searching for a trivet bit. Thanks Harry for the detailed PDF's as well.
Do you think the attached image (trivet) was accomplished with just a rounder-over bit and some sanding?
Also, I’ll try reaching out to cricket about the other account issue. Thanks.
gpstew is offline
post #7 of 9 (permalink) Old 03-19-2019, 09:41 AM
harrysin's Avatar
First Name: Harry
If I were making it I would use a straight bit, probably a bottom cutter, that is one that has a blade at the bottom and for plunge routing gives a very clean bottom cut. I would then follow with a face cutter round-over round-over bit because it is so shallow, this means that a template a template guide would be required. A similar project is shown.
TenGees likes this.
Harry
harrysin is offline
post #8 of 9 (permalink) Old 03-19-2019, 01:32 PM Thread Starter
Harry,
You're a rockstar. Thanks so much for this suggestion.
gpstew is offline
post #9 of 9 (permalink) Old 03-19-2019, 05:16 PM
First Name: Al
Cricket can do it. She just pulled my fat out of the fire....been down for two days and she got it back in a jiffy.....all u have to do notify Cricket...
HoweA is offline
Conquoring The Miter Lock Bit Jerry Bowen Tools and Woodworking 9 10-09-2016 01:43 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
Roundover bit for a circular dice tray? Colonel Travis General Routing 5 08-01-2013 12:35 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
which bit for templates and appetures please matey Router Bits - Types and Usage 5 11-02-2005 04:29 PM
