Round over bit for plywood? - Page 2 - Router Forums
 29Likes
post #11 of 15 (permalink) Old 07-30-2019, 10:35 AM
Depends a lot on the plywood. I wasted money on some Chinese crap that had a layr of bamboo strands inside. It splintered so badly it was completely useless. Baltic Birch, however, can really look nice with a roundover. Almost never use anything but BB anymore, only if I need a piece longer than 5 feet. Then I look for ply with many thin layers and pay a premium.
Another approach is to put edge banding on the ply and roundover the solid wood. This will be more decorative than a ply edge. A few years ago in an Amish area, I saw shelving of BB ply with a bullnose edge--really interesting and colorful.
1/8th would ease the edge, 1/4 would be a little more likely to tear out or spinter because it will attack 3 to 4 layers, each with grain in opposing directions.
DesertRatTom is online now
post #12 of 15 (permalink) Old 07-31-2019, 08:22 PM
BCR
agree with the 1/8 bit. As stated, and this applies to all plywood, but yes mainly cheaper stuff you would get at home depot, and the like. The 1/4 roundover is much more likely to rip out/splinter the lower layers. And as you had stated, its not really for aesthetics more as a precaution as I see it (which if that is the case, then I would add a 3/4 solid edge with perhaps a contrasting wood.)
DaninVan and gn86 like this.
BCR is offline
post #13 of 15 (permalink) Old 07-31-2019, 11:17 PM
Regular ply usually looks pretty bad when you try and round it over. Anything that I want to look good that has ply panels gets edge banded with solid wood as others have suggested. The solid wood rounds over just fine.
DaninVan likes this.
post #14 of 15 (permalink) Old 08-01-2019, 08:18 PM
pal
pal's Avatar
First Name: Harold
I usually edge band ply with solid timber if I am going to round it over If i am not rounding over I use a 1/16 roundover to take the sharp edge off either side of the ply
Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning.
Albert Einstein
pal is offline
post #15 of 15 (permalink) Old 08-01-2019, 08:52 PM
ger21's Avatar
First Name: Gerry
$20 buys you a cheap 1/2" shank bit. Check out Yonico on Amazon. Decent, and inexpensive.
As for the radius, it depends on what you are looking for.
I keep a 1/8" radius bit in a laminate trimmer to quickly ease edges. I also use 1/4" and 3/8" a lot.
Ger
www.cncwoodworker.com
ger21 is offline
