Round over bit for plywood? - Router Forums
 29Likes
post #1 of 15 (permalink) Old 07-29-2019, 03:12 PM Thread Starter
First Name: Jay
Default Round over bit for plywood?
Newb w/ first router, a used 1/2" Hitachi in a router table setup. I don't have any bits, and need a round over bit for my first project using the router. Just need to round over the edge of 3/4" plywood. Not sure what the right size is, but I'm just looking to soften the edge for comfort, not dramatically reshape it for any kind of aesthetic reason.
Maybe a 1/4" round over is the right size? Or even 1/8"?
Any recommendations for a budget bit in 1/2" shank? I don't want to spend $20 on a roundover bit, but want something better than what Harbor Freight offers.
gn86 is offline
post #2 of 15 (permalink) Old 07-29-2019, 04:11 PM
Lots of opinions amongst the members here, based on past versions of the same question. My own take on it is 'You get what you pay for!'
More expensive bits typically have better quality, thicker carbide, and are likely better factory honed. ie a better finish on your cuts.
Amortized over a longer usable lifespan, the cost of the bit is probably less for the pricier bit.
Keep your eye open for bit sales!
MEBCWD and gn86 like this.
DaninVan is online now
post #3 of 15 (permalink) Old 07-29-2019, 04:49 PM
Plywood requires a quality bit,which run around $20. like Dan said you will use it many times in the future, it is one of the most used bits in the shop.
Plywood has a lot of glue and cheap bits will wear out fast.
JFPNCM, DaninVan, MEBCWD and 2 others like this.
Herb Stoops is online now
post #4 of 15 (permalink) Old 07-29-2019, 04:59 PM
agreed....
JFPNCM, Barry747, MEBCWD and 3 others like this.
post #5 of 15 (permalink) Old 07-29-2019, 06:02 PM
A poll taken on the forum years ago stated that a 1/4" round over bit was THE most used bit among all members. It seems to be the perfect size the majority of the time and that is probably because it's the right balance for 3/4" thick material. No one has ever suggested where along the list of bit maker's Yonico's fall quality wise but they are decent and the prices are good. https://www.yonicotools.com/products...28c0fd9d&_ss=r
post #6 of 15 (permalink) Old 07-29-2019, 06:45 PM
JOAT's Avatar
First Name: Theo
If that is all you need, sanding it should do. I normally use my ROS, but a sanding stick will work just fine - just clue strips of sandpaper on wood strips.
JOAT is offline
post #7 of 15 (permalink) Old 07-29-2019, 06:48 PM
radii plane..
Veritas® Cornering Tool Set - Lee Valley Tools
post #8 of 15 (permalink) Old 07-29-2019, 10:43 PM
I am not familiar with those bits, but have heard some good reviews from time to time. Infact I have never ran across them in my travels, that I can remember.
post #9 of 15 (permalink) Old 07-29-2019, 10:50 PM
I bought a few architectural style bits a while back for future projects I haven't had a chance to get to yet but the sharpening job on them is with at least 600 grit, the carbide is thick and sharp, and even the paint finish is well done. I think I paid a little over $25 for the most expensive one which was a table edge with bullnose and ogee profile that would have cost me $100 or more in Amana, Freud, and CMT. BJ used to talk about them and he said they were good value for the money.
thomas1389, Herb Stoops and gn86 like this.
post #10 of 15 (permalink) Old 07-29-2019, 11:00 PM
Country: South Africa
First Name: Biagio
@stick , have you had much joy with those planes on plywood? I have had very variable results on solid wood - I avoid them altogether on splintery wood. Also don’t like them for longish runs, not ideal for the handholds in the OP, pliometric box.
Unlike Theo, I hate sanding, so it’s a round over bit for me. @jay , I am with Charles: the 1/4” gives a nice rounded edge on 3/4” material. Smaller gives a “smoothed” square edge. Perhaps worth trying the El Cheapos in various radii, then buying a better one in the size you prefer. As I stated elsewhere, I use El Cheapos as virtual disposables, but having tried a Lee Valley 1/4” round-over bit, I would buy that quality for frequent, long-term use, as the other guys have said.
By the way, for a 1/4” round-over, a 1/4” shaft should be adequate for most purposes, if price is the issue and you have managed to clean up your collet reducing sleeve.
Biagio is offline
