which bit for router sled? - Router Forums
 7Likes
  • 2 Post By Gene Howe
  • 2 Post By harrysin
  • 2 Post By JFPNCM
  • 1 Post By gmercer_48083
post #1 of 8 (permalink) Old 11-03-2019, 05:18 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default which bit for router sled?
I have a router sled, and want to know the best bit to use to flatten pieces of wood to a glue quality face.
For example, I have 2 pieces of walnut plank, each being a foot long x 8" wide, cut from the same large plank, and I want to glue them together to make a block.
So I need a completely smooth flat face to both.
I have used ordinary plunge bits, and even a bowl smoothing bit, but there are always lines left in the wood, making me have to sand them out, and often causing more uneven surfaces in the process.
sunnybob is offline
post #2 of 8 (permalink) Old 11-03-2019, 06:22 AM
Gene Howe's Avatar
First Name: Gene
This is what I use. Cut at about 3/32" for smooth surfaces.
Infinity planer bit.
JFPNCM and Stick486 like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 8 (permalink) Old 11-03-2019, 08:00 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I used to use a bottom cleaning bit but found that a dish cutter gives better results.
jw2170 and DesertRatTom like this.
Harry
harrysin is offline
post #4 of 8 (permalink) Old 11-03-2019, 08:26 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Gene, I shall have to see if I can buy them in the UK.
Harry, I used one of those but was not happy with the finish. I've used it in 2 seperate routers so i know its not a bearing run out problem.
sunnybob is offline
post #5 of 8 (permalink) Old 11-04-2019, 12:33 PM
JFPNCM's Avatar
First Name: Jon
I’ve used both the dish bit and a Freud bottom cleaning bit and generally prefer the latter. I recommend using the largest diameter bit for a smoother finish and as Gene points out, the thinner the cut the better.
jw2170 and Gene Howe like this.
Jon
JFPNCM is online now
post #6 of 8 (permalink) Old 11-05-2019, 11:08 AM
First Name: Gary
gmercer_48083 is offline
post #7 of 8 (permalink) Old 11-05-2019, 11:48 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I have a power planer.Never use it because its so hard to control. i had never ever thought of using it this way.
I suspect I will in the very near future, Thanks.
sunnybob is offline
post #8 of 8 (permalink) Old 11-12-2019, 10:06 AM
First Name: Brent
I sometimes use a sled for recessing housings for timber frame joinery and have actually had fine results from a spiral uncut bit. That said, the below bit is supposed to be superior and I just got one so haven't had a chance to try it out yet.
https://www.leevalley.com/en-ca/shop...ng-router-bits
I'll let you know how it works.
B
timbrframr is offline
