replacement bit for General dovetail jig 861 - Router Forums
 4Likes
  • 1 Post By Stick486
  • 1 Post By Marco
  • 1 Post By Nickp
  • 1 Post By Marco
post #1 of 10 (permalink) Old 01-12-2020, 01:03 PM Thread Starter
Default replacement bit for General dovetail jig 861
hello all...first post - picked up the above jig and the bit became dull within a couple of days....picked
up a replacement at Lee Valley (1/2 inch, 1/4 shank 14 degree) but profile isn't the same as the
bit that came with the jig....has anybody out there purchased a replacement bit for this?
thanks
Steviebee2
steviebee2 is offline
post #2 of 10 (permalink) Old 01-12-2020, 01:51 PM
Welcome N/A...
Dovetail bit profiles abound...
you need to figure out your profile and go from there...
Better quality bits matter in this department...
https://freudtools.com/explore/route...inery/dovetail
also, if you hog out the waste w/ a straight bit 1st you'll add a lot cutting capability/mileage to your DT bit...
https://freudtools.com/explore/route...ression-spiral
roxanne562001 likes this.
post #3 of 10 (permalink) Old 01-12-2020, 06:53 PM
Marco's Avatar
Hi Stevie after looking at your jig and provided bit, I had never seen a DT bit with a bearing before. The Manual says you can use a1/2" guide bushing with a 1/4" shank and a 1/2" 14 degree DT router bit. I don't see how a 1/2" wide bit will fit through a hole less than the outside diameter of a 1/2" guide bushing.
DOETAIL ROUTER BIT AND BEARINGS
Included bearings are 1/2 in. outside diameter (OD) and 1/4 in. inner diameter (ID). Router sleeves
or bushings can be used in place of the guide bearings as long as they are also 1/2 in. OD.
Included router bit is 14˚ x 1/2 in. Other bits can be substituted provided they have a 1/4 in.
diameter shank have no greater diameter than 17/32 in.
But anyway I found a bit that might work. It's Rockler's bit and there are some reviews that may be a deal breaker. You might want to call Rockler before buying and get some assurance it will work for you or guarantee of a return if it doesn't work for your jig. https://www.rockler.com/14-dovetail-...RoC3OgQAvD_BwE
Nickp likes this.
Galatians 5:13
Marco is online now
post #4 of 10 (permalink) Old 01-13-2020, 08:28 AM Thread Starter
much appreciate your quick reply and tip Stick....thanks
post #5 of 10 (permalink) Old 01-13-2020, 08:30 AM Thread Starter
thanks for investigating and finding this bit on Rocklers' site Jim...looks like it should do
post #6 of 10 (permalink) Old 01-13-2020, 08:43 AM
sreilly's Avatar
First Name: Steve
It appears this is still available so I'd call General an order or at least find out the brand/model number of the bit they supply.
sreilly is offline
post #7 of 10 (permalink) Old 01-13-2020, 08:59 AM
Danman1957's Avatar
Stevie and Steve,
General no longer exists. In Canada, the company named NORMAND INC. (Quebec & Ontario) has bought the rights to mfg. certain products and they have some parts made in different countries some in Asia and some in USA and Canada. If you look up their website you might find the router bit or an equivalent. I bought a used General air cleaner ceiling mounted and they had the filters in stock at the Laval branch. I have a couple of General machines and I love them. It's a shame they went out of business, the quality of the original stuff they made was exceptional and was seen in all local schools and many big woodworking shops. Then they tried to compete with less expensive brands and started farming out equipment to China and the rest is history
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #8 of 10 (permalink) Old 01-13-2020, 01:41 PM
Nickp's Avatar
First Name: Nick
Originally Posted by Danman1957 View Post
Stevie and Steve,
I'm pretty sure that was a different General...the jig is make by General Tools...not the other General...
thomas1389 likes this.
Nick
Nickp is offline
post #9 of 10 (permalink) Old 01-13-2020, 01:47 PM
Nickp's Avatar
First Name: Nick
The bit would go on after the guide bushing, then adjust the height. But won't work with a 1/2" shaft...needs 1/4"...
Nick
Nickp is offline
post #10 of 10 (permalink) Old 01-13-2020, 04:38 PM
Marco's Avatar
I thought about that Nick But for me, it would be a P.I.T.A. and I would likely gouge the guide bushing or something stupid along that line... not that I ever did anything like that
Nickp likes this.
Galatians 5:13
Marco is online now
