Rabetting bit VS Straight/Flush-trim - Router Forums
 1Likes
post #1 of 13 (permalink) Old 02-19-2020, 07:25 AM Thread Starter
Country: Greece
First Name: Dimitris
Default Rabetting bit VS Straight/Flush-trim
Hi everyone
I have a Triton MOF001 mounted inverted on a simple table and I have been working with straight and flush trim bits for the last year and half, building stuff and learning.
Recently I bought a cheap set of stackable slot cutters and I was amazed with how easier they cut compared to my straight bits.
So question is, should I always prefer rabbeting/slotter bits over straight bits for operations that can be completed with both types?
And if yes, should I also prefer a rabbeting bit+flush bearing (e.g. Freud 32-504) over an ordinary flush trim bit?
Dimitris3 is offline
post #2 of 13 (permalink) Old 02-19-2020, 08:29 AM
hello Dimitris...
welcome to the forums...
for cutting rabbets I prefer to use a slot cutter even though it's a 2 pass cut.. (Freud 61-102)
less waste and I get a slat that has a bazillion uses as a by product..
rabbet bits are better at their jobs and more accurate than straight bits w/easier set up too...
post #3 of 13 (permalink) Old 02-19-2020, 08:59 AM
Bstrom's Avatar
First Name: Brian
hello Dimitris...
Am I to assume you make the two cuts at right angles to one another - passes made with a horizontal (shallow pass) and vertical (deep pass) positioning of the workpiece, yielding said 'slat for a bazillion uses'? It would make a deeper rabbet more manageable (ie, less flying piece in the shop) - just want to confirm your process here, Stick. Please elaborate...
Common Man Woodworking
Powell, TN
Bstrom is offline
post #4 of 13 (permalink) Old 02-19-2020, 09:40 AM
deep horizontal cut on the edge...
then shallow cut on the face or take it to the TS...
Bstrom likes this.
post #5 of 13 (permalink) Old 02-19-2020, 11:28 AM
PhilBa's Avatar
First Name: phil
Welcome Dimitris! Always a pleasure to have people from around the world here.
You should use what ever cutters feel right to you. Straight bits are for fairly general use. Rabbets are more specialized and not as flexible but excel at the job they were made to do!
On rabbet vs straight trim. Two different uses. A bearing topped trim bit is excellent to make a flush edge. It's one of my top 2 or 3 bits. When I make boxes I use it to trim off the little bit of one side that overhangs another. Makes for a perfect joint.
Visit my shop website.
PhilBa is offline
post #6 of 13 (permalink) Old 02-19-2020, 12:04 PM
Hi Dimitris and welcome. Like Phil said use whatever bit does the job for you. If a bit does the job you wanted it to do then it was the right bit.
post #7 of 13 (permalink) Old 02-19-2020, 02:10 PM Thread Starter
Country: Greece
Thank you all for your answers!
On rabbet vs straight trim. Two different uses. A bearing topped trim bit is excellent for make a flush edge. It's one of my top 2 or 3 bits. When I make boxes I use it to trim off the little bit of one side that overhangs another. Makes for a perfect joint.
I mostly use the top-bearing trimmer (a small D:1/2",H:1") to trim 3/4" pine boards and plywood sheets. I do several passes around 1/16" to 1/8" deep and the bearing comes in the game only at the final pass (I don't have a table saw yet). What I was thinking is that with the rabbet bit+a flush bearing I could take fewer and deeper passes. Of course a trimmer bit is fine when there is not much material to remove.
That's a smart way. (at first you got me thinking how the slat comes from 61-102 - the 2nd post made it clear)
I think I had read somewhere that "you use a slotter/rabbet where you can't use a straight bit". After trying the slotter bit I thought that it should be the other way round...
post #8 of 13 (permalink) Old 02-20-2020, 08:02 AM
sreilly's Avatar
First Name: Steve
Welcome Dimitris to the forum. Great 1st question and as you can see there are usually several (many) ways to accomplish the same results in woodworking. I recently bought my first planner bit and then decided to use it to make my tenons now that I have a mortising machine. Setting the fence to proper depth on the router table, one of my favorite tools these days, and using a backer board made quick work of a very smooth and accurate tenon. For anything that required deep cuts, say over 3/16" I simple made height adjustments and did several passes. Of course I could use the band saw or table saw.
sreilly is offline
post #9 of 13 (permalink) Old 02-20-2020, 11:12 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum!!
roxanne562001 is offline
post #10 of 13 (permalink) Old 02-20-2020, 11:39 AM
MEBCWD's Avatar
Welcome to the Router Forums Dimitris.
MEBCWD is offline
