Looking for a spiral flush trim with more than 2" capacity - Router Forums
 7Likes
post #1 of 18 (permalink) Old 02-28-2020, 10:00 AM Thread Starter
Default Looking for a spiral flush trim with more than 2" capacity
Anyone out there know of a spiral flush trim bit with a cutting capacity over 2"?
Can even be a bit for a shaper doesn't matter.
Thank you
Poplarguy is offline
post #2 of 18 (permalink) Old 02-28-2020, 10:30 AM
This bit is 4" long, w/2" cutting capacity , you would have to make more than one pass to cut 3" deep. What are you trying to cut?
https://www.amazon.com/SpeTool-Cutti...xpY2s9dHJ1ZQ==
Herb Stoops is online now
post #3 of 18 (permalink) Old 02-28-2020, 10:34 AM Thread Starter
Thanks Herb, that's not a flush trim bit though!
post #4 of 18 (permalink) Old 02-28-2020, 10:46 AM
PhilBa's Avatar
First Name: phil
Several companies make a spiral trim with a 2" CL - Freud 75-509, Amana 46304. way expensive, though.
Visit my shop website.
PhilBa is online now
post #5 of 18 (permalink) Old 02-28-2020, 10:51 AM
TenGees's Avatar
First Name: Paul
Maybe use Herb's suggestion with an edge guide?
TenGees is online now
post #6 of 18 (permalink) Old 02-28-2020, 11:29 AM
Carbitool Flush Trim Router Bit - Carb-I-Tool
The last one on the list is 3 7/8" OAL w 2"cutter, Not spiral tho.
HErb
post #7 of 18 (permalink) Old 02-28-2020, 12:03 PM
Nickp's Avatar
First Name: Nick
If you look at Herb's example, couldn't you use the shaft as the edge guide...? After making a shallow cut and edge with a shorter trim bit...?
Nick
Nickp is online now
post #8 of 18 (permalink) Old 02-28-2020, 12:47 PM
The last one I listed has a BB on it. the bottom one in the chart.
Nickp likes this.
post #9 of 18 (permalink) Old 02-28-2020, 02:01 PM
Nickp's Avatar
First Name: Nick
Thanks...I shudda said your FIRST example...
Herb Stoops likes this.
Nick
Nickp is online now
post #10 of 18 (permalink) Old 02-28-2020, 03:41 PM Thread Starter
Thanks guys, I know there are several good quality spiral bits with 2" cutting capacity on them, but as we've seen there doesn't seem to be anything over that 2" capacity. It's gotta be a spiral bit with bearing for flush trim.
I'm hoping to put round corners on thicker cutting boards with a round corner template... fast, easy and more importantly... accurate.
But I can't cut anything over 2" thick, was hoping to make a few thicker cutting boards by request.
