Broke 2 upspiral bits in 20min (and damaged the collet) - Router Forums
 11Likes
post #1 of 17 (permalink) Old 04-08-2020, 05:26 PM Thread Starter
Default Broke 2 upspiral bits in 20min (and damaged the collet)
Hello,
I am cutting 1/4 wide/ 3/4 deep mortise using and upspiral bit. I Have cut hundreds of those mortises this way in the same species (ash) but this time I broke 2 bits in like 20 min and damaged my collet in the mean time. Now I'm out of the shop waiting for a new collet from the mail
What I normally do is a full plunge on both end of the mortise then rout between 3 x 1/4 deep for a total of 3/4 deep. Never had any problem. Now this time I Don't know why but broke 2 bits when plunging full depth at each end. It's like the bit bites in the wood on the last 1/8" or so. Nothing special here same technique like the last hundreds I did but this batch of ash seem different. Table saw was burning it like hell and thickness planer was making tearout sound no matter wich side i feed first.
So I will have to modify my mortise technique. How do you guy do it in very dense & hardwood. I know routing in increment is key but regarding the plunging part, how would you approach it.
My take on this would be to first rout the bulk of the slot using 3 x 1/4 increment staying shy of the ends(Maybe 1/16). when this is done then I will do full plunge at the end leaving more room for the chips to go. It's kinda like the usual method most use but in reverse.
what do you thinks
stgpascal is offline
post #2 of 17 (permalink) Old 04-08-2020, 05:35 PM
the wood was either dried at a high temp for faster processing or baked too long accidentally or or high temp w/ longer kiln time because it was to high of an MC when it wen into the kiln...
there's a most excellent chance your wood was tempered/hardened....
was are your external and internal MC's???
post #3 of 17 (permalink) Old 04-08-2020, 05:36 PM
what brand of bit are you using???
post #4 of 17 (permalink) Old 04-08-2020, 06:44 PM Thread Starter
thanks for your answer the bits are freud ones
as for the MC I dont have a way to measure it on hand we are in lockdown. It was air dried by another woodworker who stopped woodworking and sold it to me after it has sat in hia shop for years.
what I can say about its appearance is that this board is very different from the other. It is supposed to be ash but it is heavier, more prone to burn and the open grain structure is very tight.
It is in workpieces coming from this board that the bit broke.
anyways these fellas wil be mortised whether they like it or not.
what do you think of the slightlt different method I proposed in the op
post #5 of 17 (permalink) Old 04-08-2020, 07:00 PM
JOAT's Avatar
First Name: Theo
You can still order stuff on-line to be delivered.
JOAT is online now
post #6 of 17 (permalink) Old 04-08-2020, 07:24 PM Thread Starter
yes I know but right now in canada what used to take 3-4 days to arrive now takes about 1.5 month.I have ordered freud router bits from amazon about 3 weeks ago, they are still waiting to be shipped. Used to take about 5 days to arrive. SO even if I order a moisture meter I would be able to respond like in may.
But regardless of MC does the different method would lead to less chance of Breaking :
-Rout the bulk of the mortise using 1/4 pass and staying about 1/16 shy from the ends up to 1/2 deep
-On the final 1/4 I plunge the full 3/4 on the ends wich will have lots of roomfor the chips to go then rout the final 1/4 (total 3/4 deep)
post #7 of 17 (permalink) Old 04-08-2020, 07:44 PM
since it was air dried...
that leaves...
it isn't Ash...
and I'm WTB it's still hardened, sunlight will do that ....
you could be hitting wild grain.. (a knot)
is this the bit you are using???
https://www.freudtools.com/explore/r...al/compression
have you considered a double flute straight bit???
https://www.freudtools.com/explore/r...flute-straight
chatter is a bit breaker...
you said you tore up your collet...
how in world did you do that???
one way was not having your bit fully encompassed by the collet, only partially..
is there run out in your router's shaft???
BTW..
do we still keep calling you N/A for a 1st name???...
post #8 of 17 (permalink) Old 04-08-2020, 08:20 PM Thread Starter
haha you can call me Pascal
The bit is an upspiral fullcarbide one. The collet did not tore but the 2nd bit broke in the collet so it left a mark inside the collet. Other bits became very had to slip into the collet so I feared this would be a receipe for disaster.
post #9 of 17 (permalink) Old 04-08-2020, 08:44 PM
well Pascal...
ditch the N/A and put you in it's place...
feed rate is too fast for the wood...
smart thinking on the collet...
post #10 of 17 (permalink) Old 04-08-2020, 11:28 PM
I've always found that removing as much of the waste as is practical results in easier routing and about 1/3 as much wear on the bit. If you're grooving then make a pass or two on the table saw first. In this case I would drill as many holes as possible with a 3/16" bit. Drilling is fast and easy and drill bits are cheap. If you set up accurately on a drill press with a fence to keep you inside the mortise lines then you could go with a 1/4" and then all you have to rout is the points between circles. Even if you are off a tiny bit with the drilling that's not a bad thing because it gives the air in the mortise a way to escape if the fit is otherwise very tight.
DaninVan, Stick486, Ed3443 and 1 others like this.
