A "little bit" with Festool - Router Forums
post #1 of 2 (permalink) Old 10-18-2009, 05:22 PM Thread Starter
charimon's Avatar
First Name: Craig
Send a message via Yahoo to charimon
Default A "little bit" with Festool
I spend a lot of time over at festool owners group we had a show us your shop contest and a member showed a couple pis that you all might like.
The pic and following captions are from Roger Savatteri
The "bit" is 6 inches long with a 4 3/8" cutting edge.
The diameter at the widest is 3 1/2", with a 5/8" bearing.
And my guiding light was the Festool Rail system and micro-adjust guide coupled with a bridge system suspended on MFT 800's.
Note- When your using a bit that is a little over 3 1/2 inch at the base, which leaves about a fat 1/8" clearance to the routers side walls-
Break out you broom for the big stuff!
P. S. I went 32 linear feet without a hiccup. (.....and yes I have video for a later date/sysnotes)
Here is the link Celebrate 7000 Members and Growing with the "Show Us Your Shop Giveaway"!
Thanks Craig
If you eat what you kill. You better HUNT !!!!
charimon is offline
post #2 of 2 (permalink) Old 10-18-2009, 05:47 PM
Hi Craig
I will try most things but I would pass on that bit
They make a machine to do that type of job safe..
" molding machines " see one on the NYWS (Norm's)
Festool router set-up Dogtrot Table-mounted Routing 0 04-17-2009 12:15 PM
Kapex by Festool woodchip7 Tools and Woodworking 4 03-18-2008 06:28 PM
Festool Routers Gror Tools and Woodworking 2 09-29-2006 08:39 AM
Festool ejant Tools and Woodworking 6 11-13-2004 10:08 PM
