Stuck Router Bit - Router Forums
 1Likes
post #1 of 12 (permalink) Old 01-30-2010, 04:57 PM Thread Starter
Noj
First Name: Jon
Default Stuck Router Bit
Hi,
I have a straight router bit stuck in my Bosch 1615 plunge router. When I put the bit into the router, I pushed it all the way in until it hit the bottem before tightning the collet (I didn't know you shouldn't do that at the time). I have loosened the collet (even took the collet all the way off). I put a towell over the bit and pushed/pulled the bit different directions but the bit did not move or loosen. I very lightly tapped the bit with a small hammer but again the bit did not move or loosen. I do not want to tap the bit any harder because I do not want to damage the bearings or router in general. Please help me free my router for a new project!!!! Any ideas? Thanks, Jon.
chapXI likes this.
Noj is offline
post #2 of 12 (permalink) Old 01-30-2010, 05:13 PM
Hi Jon
Heat will free most items
Use your heat gun or a good hair dryer ,rap a wet rag around the shaft of the router ,put some heat to it , get it warm ,not to hot ,tap the bit shaft with a soft hammer (rubber face/brass face) than put your cloves on and pull the bit out ..
Originally Posted by Noj View Post
Hi,
post #3 of 12 (permalink) Old 01-30-2010, 05:26 PM
xplorx4's Avatar
First Name: Jerry
Greetings Jon and welcome to the router forum. Thank you for joining us. BJ's the man!!
Lamentations 3:22-23
xplorx4 is offline
post #4 of 12 (permalink) Old 01-31-2010, 02:35 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Jon. Glad to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 12 (permalink) Old 01-31-2010, 04:44 AM
Mike Wingate's Avatar
First Name: mike
I hope that you get it out o.k. I bet you don't do that again. Place a rubber grommet in the bottom of your collet shaft, it will allow a little bit of give and no more stuck bits.
Mike Wingate is offline
post #6 of 12 (permalink) Old 01-31-2010, 08:23 AM
allthunbs's Avatar
First Name: Ron
Hi,
Hi Jon:
My solution is to remove the nut, sleeve and bit from the router.
Take a look at where the spindle lock is on the router. Now, there are two flat surfaces on the armature. Get yourself a cheap, flat wrench that will fit those flat spots without disturbing the spindle lock.
Next, get a flat wrench that fits the collet nut. Now, position the spindle wrench, then the collet wrench. The collet nut will be lefty loosy and righty tighty. THat is, the nut should turn counter clockwise while looking at the bottom of the router while the base is pointing at the ceiling.
Undo the nut completely. It will be trapped between the bit and the collet but that's OK.
Take the collet parts over to a vice or find some way of supporting the shoulders of the _collet_. You want to support the collet while tapping with a hammer and an old drill bit on the bottom of the shaft of the bit. Eventually it will come out. You might consider something like WD40 if the bit is really valuable. Make sure you clean the shaft of the bit thoroughly afterward.
When all is said and done, _replace the collet._ There's nothing worse than trying to rely on something that is always getting stuck and it's a real pain to always be trying to unstick bits.
BTW, the two wrench method is far superior to the spindle lock. You might consider removing the spindle lock entirely and just using the two wrenches.
Allthunbs
allthunbs is offline
post #7 of 12 (permalink) Old 02-14-2010, 01:28 PM Thread Starter
Noj
First Name: Jon
Thanks for all the good ideas!!! I finally got the router bit out without destroying my bosch router!! Now I will take the bit out each time I am finished with a project.
OK, now for stuck router bit number 2 problem! I have a Delta two speed wood shaper. It has been sitting for about 10 years with a round over bit in it. I am just getting back into woodworking after a 10 year respite. So... I need to change bits in the wood shaper. I cannot get the collar holding the bit to budge at all. I have removed the arbor from the shaper. I have tried several types of wrenches on the arbor/collar to loosen it. I have applied a generous amount of 10 W 40 to the threads. I have tried loosening it both directions but I am still following the "lefty loosey/righty tighty" rule. Should I put the arbor out in the cold like someone suggested or heat it up like someone else suggested? Any other suggestions? This seems like a more significant problem than the Bosch router since I can't begin to budge/loosen the collar with the bit in it. Thanks ahead of time for all your input!! Jon.
Noj is offline
post #8 of 12 (permalink) Old 12-05-2011, 10:39 AM
Corky's Corner's Avatar
First Name: Corbett
Just a quick thought: Try Liquid Wrench instead of WD-40. LW penetrates and lubes, WD-40 might not do what you need.
Corky's Corner is offline
post #9 of 12 (permalink) Old 12-05-2011, 02:19 PM
Jon, I would suggest PB Blaster as an alternative to Liquid Wrench. I have had better results using it. About your Bosch router, this router has a double release self extracting collet. This means that the nut will loosen and then tighten again. Keep turning and it will then allow the bit to come out freely.
post #10 of 12 (permalink) Old 07-21-2014, 04:24 AM
Rig30mechanic's Avatar
First Name: Lawrence
The better alternative to WD40 is 50% Acetone and 50% ATF. Home-made brew that is the best for un-seizing stuck parts.
Lawrence
Rig30mechanic is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 11:01 PM
Replacing Router paerley General Routing 11 01-22-2010 01:49 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 07:56 AM
