Help me find this bit! - Router Forums
post #1 of 13 (permalink) Old 05-08-2010, 03:33 PM Thread Starter
Default Help me find this bit!
I am looking for a 1/4" cutting diameter top bearing pattern/Template bit.
The thickest material I am cutting is 9mm Marine Plywood, if I could do two sheets at once that would be great also but not necassary. I want a narrow bit to get as many copies as possible out of a sheet of wood, and Marine ply is expensive!!!
I want a quality bit, I don't want to worry about the quality of the tool causing any issues, problem is I have not found one for sale yet. If I can't find a 1/4" cut I will go with 1/2", those seem readily available.
I have not picked up my router yet, I was thinking about the Sears kits for around $100, or consider just getting the plunge router without extra bases from Bosch.
Thanks,
Nick
kcinnick is offline
post #2 of 13 (permalink) Old 05-08-2010, 04:39 PM
BigJimAK's Avatar
Nick,
If I found one, I would not buy it. To get a 1/4"OD bearing, if you could find a 1/4OD by 1/8"ID (1/16" bearing wall thickness), you'd still only have an 1/8" shank under the bearing spinning a ~1" long 1/4" diameter cutter beneath it.
If you go with a 1/4" shank 1/2" cutter, you can use a 1/2"ODx1/4"ID bearing on the shank with a bearing retainer. This has worked well for me.
BigJimAK is offline
post #3 of 13 (permalink) Old 05-08-2010, 04:40 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
I'm not sure you'll find one. The bearing is likely to need IIRC 3/16" to mount on, leaving only 1/32" each side for the race, if you see what I mean.
Fundamentally, any 1/4" bearing is likely to have a central mounting hole that would be too small to safely mount it on a cutter going at the sort of speeds used in a router, so I don't think anyone would do a bearing guided bit this small.
HTH
Peter
istracpsboss is offline
post #4 of 13 (permalink) Old 05-08-2010, 04:46 PM
Country: Croatia
First Name: Peter
Looks like we were typing at the same time Jim !
Cheers
Peter
post #5 of 13 (permalink) Old 05-08-2010, 05:54 PM Thread Starter
Looks like you (Both of you) are right. I guess I will go with a 1/4" cutting diameter.
kcinnick is offline
post #6 of 13 (permalink) Old 05-08-2010, 06:50 PM
Hi Guys
I have a 1/4" shank trim bit with a 1/4" wide cutter and a 1/4" OD bearing on it, it's one of the best ones I have, great to get in the tight pocket cuts, I found it at all places, HD for 15.oo bucks..
http://www.holbren.com/flush-trim-spiral/
post #7 of 13 (permalink) Old 05-08-2010, 06:51 PM
BigJimAK's Avatar
Great Minds Think Alike!!
Originally Posted by istracpsboss View Post
looks like we were typing at the same time jim !
Cheers
peter
BigJimAK is offline
post #8 of 13 (permalink) Old 05-09-2010, 07:22 PM
Country: Croatia
First Name: Peter
Hi Guys
Flush Trim - Spiral - Holbren
We stand corrected ! I wouldn't have thought it feasible but Whiteside can't be wrong.
Cheers
Peter
post #9 of 13 (permalink) Old 05-09-2010, 10:14 PM
Cheers
Peter
Peter, I think maybe you are both right. OP was asking for a "top bearing", which I interpret as shank mounted. MLCS also has tip mounted spiral flush cuts.
John Schaben
jschaben is offline
post #10 of 13 (permalink) Old 05-09-2010, 10:37 PM
Hi John
I didn't know MLCS had a true 1/4" one how about a link to that one I'm always looking for deals on bits.
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 01:38 PM
I think I settled on a starter bit set. Any C&C? Skyglider Router Bits - Types and Usage 40 12-28-2008 10:23 PM
How to do a bullnose with a roundover bit? LBrandt Router Bits - Types and Usage 2 06-10-2006 07:10 PM
plywood glue bit keith Table-mounted Routing 4 03-03-2006 11:06 AM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 10:03 PM
