Collet extension question - Router Forums
post #1 of 9 (permalink) Old 07-26-2010, 06:44 PM Thread Starter
First Name: Ken
Default Collet extension question
I would like to order a collet extension from MLCS ,the one for 1/2" router bits but since I have a lot of 1/4" bits I was thinking of using a 1/4" adapter for them.
My question is is it possible to use a 1/4" adapter/sleeve on a 1/4" bit then put both in a 1/2" extension and have no vibration?
I mean would it be the same as using a 1/4" extension?
Thanks for your help.
distrbd is offline
post #2 of 9 (permalink) Old 07-26-2010, 07:11 PM
Hi Ken
It's best to use the right tool for the job but you will have a very small run out by using the adapter sleeve , no way around it because of the split in the adapter but I will say I do it that way from time to time and you will not see a big diff. unless you use big 1/4" shank bits , not the norm..
post #3 of 9 (permalink) Old 07-26-2010, 07:40 PM Thread Starter
First Name: Ken
Thank you BJ.
I know the run out is only .006" but by the time the adapter and the bit are added vibration could be noticeable but as you mentioned I'll have to limit the size of the 1/4" bits I'm using which is just what I was planning to do .
I"ll be using bits like V groove,spiral , key hole ,the biggest would be a Rabbeting bit.
distrbd is offline
post #4 of 9 (permalink) Old 07-26-2010, 11:58 PM
BigJimAK's Avatar
Ken,
MLCS offers the 1/4" and 1/2" w/wrenches as a set for $49..
MLCS Router Collet Extension and Review
I just picked them up (and a bowl bit) to try out a version of Harry's bowl-making technique. I've got the wood. I've got the bits. Now just to get the shop time! <g>
BigJimAK is offline
post #5 of 9 (permalink) Old 07-27-2010, 10:02 AM Thread Starter
First Name: Ken
Originally Posted by BigJimAK View Post
Ken,
That's a good price ,may be I'm better off either buying the set or not bother with it at all.
I know if I buy an extension I will only use it occasionally so is it Worth paying that much for occasional use ?I'll see,I may just forget about it.
Thank you for your reply.
distrbd is offline
post #6 of 9 (permalink) Old 07-27-2010, 10:33 AM
Honored Member
harrysin's Avatar
First Name: Harry
I only use an extension when I'm deep routing and it's the only way to complete the job. Vibration is my experience. There are three types of 1/2" to 1/4" reducer sleeves, the one on the right is first choice and on the left the last choice.
Harry
harrysin is offline
post #7 of 9 (permalink) Old 07-27-2010, 07:29 PM Thread Starter
First Name: Ken
Thank you for your reply Harrysin.
I see why you like the one the right,The one I have is worst of the 3 so dealing with vibrations using that sleeve is going to be a problem.
I'm not going to get the extensions for now unless I have a project that needs one .
The main reason I thought about buying one was I wanted to use a 1/4" shank dovetail bit in an OP jig and the bit was too short but now instead of using an extension I bought a longer bit and solved the problem .
Thank you all for your replies.
distrbd is offline
post #8 of 9 (permalink) Old 07-28-2010, 02:49 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
George sells extra length dovetail bit sets to suit several dovetail jigs. See 16 pc 1/4 Shank Dovetail Router Bit Set For Leigh Jig - eBay (item 130413382333 end time Jul-30-10 16:40:49 PDT)
Cheers
Peter
istracpsboss is offline
post #9 of 9 (permalink) Old 07-28-2010, 05:26 AM
Honored Member
harrysin's Avatar
First Name: Harry
You really have made the right choice Ken. The box shown, routed from solid wood was one of less than a handful of projects where I have used the extension.
Harry
harrysin is offline
dewalt 621 collet question diegoh2 General Routing 3 04-20-2010 10:34 PM
Collet Extension will.ellis New Member Introductions 6 03-23-2010 12:48 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
Collet extension diameter?? Pirate General Routing 3 08-10-2009 02:09 PM
