Bench Dog Hole Bit: 3/4" plunge (long)??? - Router Forums
post #1 of 11 (permalink) Old 03-01-2011, 01:07 AM Thread Starter
RouterForums.com User
Default Bench Dog Hole Bit: 3/4" plunge (long)???
I've been keeping my eyes out for a 3/4" plunge bit for starting bench dog holes. Ideally it'd be 1/2"SH and 4" long or so.
I've seen plenty of 3/4" bits but none labeled as plunge. I know I could use a forestner but a plunge router seems like the ideal way to drill a perfectly perpendicualr hole (yes, that's what I need).
It seems like my On-Point laser base, router and 3/4" plunge bit would be a perfect apporach for dog holes! <ruff>
BigJimAK is offline
post #2 of 11 (permalink) Old 03-01-2011, 09:56 AM
MLCS Plunge Cutting Straight Router Bits
I dunno where to get one 4" long though. I'm guessing your bench is 2-3"?
This may work better than my first link though
http://www.mlcswoodworking.com/shops...ral_hss_anchor
John Schaben
jschaben is offline
post #3 of 11 (permalink) Old 03-01-2011, 10:21 AM
Hi Jim
The router is a great tool but not always the right tool,you can make a jig to hold your drill motor and drill a strait hole and use the bit below..or if want a real clean hole use the 5/8" auger bit and than use your new longer router bits and template to clean the holes out to a true 3/4" hole with your router for the dogs..
By the way if you grind off some of the lead thread on the drill bit it will cut a nice clean hole..the threads are in place to pull the drill bit in quick..
3/4 x 4-1/2 In. Solid Center Auger Bits
Irwin 49912 3/4 x 4-1/2 In. Solid Center Auger Bits
post #4 of 11 (permalink) Old 03-01-2011, 11:39 AM Thread Starter
MLCS solid carbide router bits
Thank you, John...
I'm just getting ready to glue up a working-prototype workbench top and, to be honest, I'm still vascillating on how thick to make it... but yes, it'll be thick.
That's quite a choice there, John... I really like the spiral bit... it'd be good for my softwood prototype but I wonder if the HSS would hold up to ~35 plunges to full depth in hard maple??? Hmmmm.... I guess it probably should as long as you give time for cooling between cuts.
BigJimAK is offline
post #5 of 11 (permalink) Old 03-01-2011, 12:09 PM
Ralph Barker's Avatar
First Name: Ralph
Ralph Barker is offline
post #6 of 11 (permalink) Old 03-01-2011, 12:10 PM Thread Starter
Hi Jim
Hi Bob,
Using an auger bit was already my back-up plan but I hadn't considered making it undersized and then cleaning it out with my new "George bits"... great idea!! Those bits, after getting lost by the USPS, are supposedly now in Anchrage and being delivered today. I was going to use the long ones to trim the bench-end perpendicular to the top of the bench anyway.
Although it wouldn't be an issue for my softwood top, would an auger bit hold up to drilling 8 - 10' total in hard maple? I've seen several advertisements cautioning about short bit life in wet or hardwood. Is there something special I should be looking for or is it just a matter of pausing regularly to keep the bit cool? I could always pause regularly and shoot a blast of air into the hole to clear the chips (and cool the bit).
Jim
BigJimAK is offline
post #7 of 11 (permalink) Old 03-01-2011, 12:43 PM
Mike Wingate's Avatar
First Name: mike
I use 3/4" square bench dogs on my benches. I route the grooves across the edges, and then put extra lengths alongside to the widen the bench on both sides. Thus I have square holes running 3" inside the edges of the bench. I have done this on a number of benches, both solid and manmade centres to the bench with solid dog areas. If you want round dogs, turn the tops round. My Rockler Bench Cookies fit in the dog holes on their extensions.
Mike Wingate is offline
post #8 of 11 (permalink) Old 03-01-2011, 01:52 PM
Hi Jim
They are HSS and you can put a new edge on them very easy but just put some candle wax/paraffin (canning wax) on them and they will stay cool.. don't use water on them or any water base lube they will rust up in time.. I have many from 1/4" to 3" in diam. and from 4" to 20" long they do come in handy
Hi Bob,
Jim
post #9 of 11 (permalink) Old 03-01-2011, 10:05 PM
I drilled a hole with a drill press through a 4x4 and used it to start the holes straight.
post #10 of 11 (permalink) Old 04-08-2011, 01:43 PM
First Name: Richard
Ralph, I bought one of thoes General guidess and am going to throw it in the trash. There is almost 1/4" of play in the chuck so that when I put a bit in it and try to drill I get a side to side motion along with the spinning motion . I thought it might have just been a bad one but took it back to the store and checked 3 more in the boxes and they all the same issue.
Racer2007 is offline
Bench Dog Pro Top Contractor bit opening biggdogg Table-mounted Routing 1 02-16-2010 08:33 AM
bit hole size Phillym Table-mounted Routing 1 12-30-2008 07:14 PM
base plate for mortising? How make it? help Bogydave Jigs and Fixtures 12 11-17-2008 02:15 PM
hole saw vs forstner bit reds_21 Tools and Woodworking 6 03-20-2005 09:48 AM
