Router bit bearing - Router Forums
post #1 of 6 (permalink) Old 04-17-2011, 09:05 AM Thread Starter
First Name: Dave
Default Router bit bearing
Id like to know If anyone can tell me where I could find a 1 3/4" O.D. bearing with a 5/16" I.D. Im trying to set up a 1 7/8" slotting bit cut a 1/16" deep slot. Thanks Dave
David2058 is offline
post #2 of 6 (permalink) Old 04-17-2011, 10:29 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
istracpsboss is offline
post #3 of 6 (permalink) Old 04-17-2011, 10:51 AM
Hi David
I'm not sure if you miss this one, But I don't think you will find one, it's almost a make your own thing.
Router Forums - View Single Post - slot cutting bit
For your fly fishing gear..
http://www.routerforums.com/228605-post6.html
post #4 of 6 (permalink) Old 04-17-2011, 01:15 PM Thread Starter
First Name: Dave
Hello again Bob. I did try your idea about using a press on adapter of UHMW plastic. after several trips around the frame of the fish net the plastic began to wear and shread. It worked well for a short time but broke down. It seemed like that was the ticket, I just couldnt make it work
post #5 of 6 (permalink) Old 04-17-2011, 01:17 PM Thread Starter
First Name: Dave
P.S. I was using it a the lowest speed possible
post #6 of 6 (permalink) Old 04-17-2011, 01:32 PM
Hi David
Pickup some Alum.it should stand up longer..but the disk should spin on the shank (bearing) and not on the stock.
It will mill out just like the UHMW plastic.
I have used the tool below for jobs like the one you are doing.
Dremel makes many saw blades,,you can stack the blades to get the 1/16" that you want.
http://www.amazon.com/Dremel-670-Min...3066070&sr=1-6
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 12:38 PM
Whats the difference between router and shaper bit? sofasurfer Router Bits - Types and Usage 5 06-15-2009 01:54 PM
