Router bits for Mortise and Tenon project? - Router Forums
 14Likes
post #1 of 268 (permalink) Old 08-07-2014, 03:09 PM Thread Starter
First Name: Elley
Default Router bits for Mortise and Tenon project?
I am getting ready to start work on a dining room table which will involve a mortise and tenon breadboard joint and was wondering what types of router bits would work best to do the job.
The breadboard will have a mortise depth of between 2 1/4 and 2 1/2 inches, and will also have a continuous 1/2" groove for a stub tenon. My tenons are going to be 1/2" thick on 1 1/4" sassafras.
This will be my first mortise and tenon joint, so if anyone has any other suggestions I could use the input!
windhollowfarm is offline
post #2 of 268 (permalink) Old 08-07-2014, 03:25 PM
Welcome to the forum Elley. Those are pretty deep mortices so you may only be able to find straight bits in that length (and at a price you are willing to pay). It should be plunge capable as not all are. Mortices should be slightly deeper than the tenon that will go in them. I would also remove (hog out) most of the waste wood by drilling first. Whiteside Machine has a 2 1/2" cutting depth, 1/2 diameter, 1/2" shank bit that would work. The part # is 1073. Amazon is usually a good place to look for the best deal.
post #3 of 268 (permalink) Old 08-07-2014, 04:17 PM
Honored Member
First Name: pat
Way too deep & too many for routing.
Time for power tool purchase (Morticer).
Quillman is offline
post #4 of 268 (permalink) Old 08-07-2014, 04:45 PM
which style are you gong with???
https://www.google.com/search?q=brea...eo%3B320%3B240
post #5 of 268 (permalink) Old 08-07-2014, 04:50 PM
got dado blade and table saw???
slot cutter for the router???
post #6 of 268 (permalink) Old 08-07-2014, 05:02 PM Thread Starter
First Name: Elley
No to the dado blade, table saw and slot cutter - I am hoping to do this with my router, jigsaw, and various hand tools. My BIL has a table saw, but the table top is going to be over 80" long. Thinking of something similar to the pic attached, but was thinking of doing 5 tenons rather than 3.
post #7 of 268 (permalink) Old 08-07-2014, 05:07 PM Thread Starter
First Name: Elley
Thank you for the info, Charles!
I will do some searching. The breadboard is 5 1/2" right now, but I could rip it down to less so the mortise doesn't need to be as deep. It's quite a large table top - finishing around 34" x 87"
post #8 of 268 (permalink) Old 08-07-2014, 09:38 PM
To be honest Elley, my first thought when I read your first post was the same as Quillman. A morticing machine or drill press morticing attachment would be the best. However, you would have to mount it in an open window and hang the boards outside to do 80". Still, those are really deep mortices. If I were going to try and do that with a router I would try and have almost all the waste wood removed and just do a light finish cut with the router and probably in stages of depth. This isn't a particularly easy task.
I would tend to go at least partly like Stick is suggesting and use a table saw. You can easily make a deep groove with a table saw and tenons are easily done with a straight router bit to almost any length you want them.
Have a good look at the pictures in Stick's link. It shows in one picture glue being applied only to the middle of the assembly. The table is going to expand and contract across it's width with seasonal humidity changes so you have to allow it to move or you will get cracked boards and joints. I really like the idea of the dovetail in the one picture but it is a much more difficult job.
post #9 of 268 (permalink) Old 08-07-2014, 10:05 PM
Semipro's Avatar
First Name: John_*
I guess I am missing something normally you only bread board the end, are doing the whole circumference of the table.
Is this solid wood table or hardwood plywood center, if solid wood do your machining before glueing your top up, material will be easier to handle.
I also believe that you could cut down the size of mortice and tenon and still use a 5 1/2" bread board
Semipro is online now
post #10 of 268 (permalink) Old 08-07-2014, 10:10 PM Thread Starter
First Name: Elley
Thank you all so much for the input and help! I will be doing some research on how to remove the waste wood, and do some practice work before working on the good wood. I'm making myself a list so I don't forget any steps. :-)
For Sale: F/S Leigh FMT Jig - Cut Precise Mortise & Tenon Joints With Your Router Paul Joynes Woodworking Classifieds 5 06-06-2012 09:15 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
loose tenon router bits vjeko General Routing 2 02-09-2009 05:28 PM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
Mortise & Tenon System Router questions kenadian Table-mounted Routing 2 11-17-2005 04:22 PM
