Bit For Edge Jointing - Router Forums
post #1 of 27 (permalink) Old 12-10-2014, 02:31 PM Thread Starter
Default Bit For Edge Jointing
Looking for the best bit for edge jointing on the router table.. Figuring a up spiral 1/2 Whiteside would do the trick but not sure if a compression bit would be better?
Thanks for any advice!
jackson74 is offline
post #2 of 27 (permalink) Old 12-10-2014, 04:37 PM
Welcome to the forum, Jackson....
I use a 2" long 1/2" shear bit...Works ok for me...
http://www.carbatec.com.au/806-super...im-bits_c17510
Sydney, Australia
jw2170 is offline
post #3 of 27 (permalink) Old 12-10-2014, 05:32 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the forum.
Thank You John
Semipro is online now
post #4 of 27 (permalink) Old 12-10-2014, 05:59 PM
Welcome to the forum Terry. The up spiral might do a bit better but pricey compared to straight bits with or without a shear angle. I would try a straight bit first with a large diameter, for example 1.5". I think the larger diameter will help with a better cut.
post #5 of 27 (permalink) Old 12-10-2014, 06:48 PM
Gaffboat's Avatar
First Name: Oliver
+1 with James.
Gaffboat is offline
post #6 of 27 (permalink) Old 12-10-2014, 07:00 PM
i use a 2" long 1/2" shear bit...works ok for me...
+2....
post #7 of 27 (permalink) Old 12-11-2014, 01:18 AM Thread Starter
Default Thanks...
Thanks for the help..
So if reading this correctly it seems more or less the opinion is that a large diameter straight bit probably does a good enough job not to warrant the price costs for the spiral cutter..
Sounds good to me to try for awhile .. I will post my results once I get running the bit and glue up some panels..
Thanks for the warm welcome
post #8 of 27 (permalink) Old 12-11-2014, 07:50 AM
First Name: Buck
Over the years I've come across two very different theories on this. One says that you want a perfectly smooth edge on both pieces to be mated and the other says you don't want it real smooth to get a better/stronger glue joint. I went with the latter theory because it was quicker and easer. I run the pieces through the table saw with the fence just a HAIR off of being parallel to the blade. I make the edge banding a little wider than the piece it is being glued to which means the glue up doesn't have to be as precise. I then use my router to trim the edge band flush with the mating piece. I have edge bands that have been on for 20+ years with no problems and in cases where the pieces are of the same wood with the grain running in the same manner you can't see the joint.
Buck
BOjr is offline
post #9 of 27 (permalink) Old 12-11-2014, 09:32 AM
Phil P's Avatar
First Name: Phil
Forgive me saying this, Buck, but if you've already run the material through the table saw then all it takes is a couple of passes with a sharp, finely set jointer plane (something lIke a Stanley #7) to get a really good jointed edge. That's a lot less work than any router table set-up in my experience. Sometimes the simple solutions work best
BTW you're right about wanting a smooth edge - roughened edges are impossible to correctly check for hollow joints and never seem to make a tight joint
Regards
Phil
Phil P is offline
post #10 of 27 (permalink) Old 12-11-2014, 09:34 AM
PhilBa's Avatar
First Name: phil
I think it depends on what your goal is. Extra strength or invisible glue line. Either way will produce a solid glue joint. More surface area (rougher edges) will be stronger but smooth will still be plenty strong. The glue line of the smoother joint will be less noticeable.
By the way, I've heard an argument against rough that goes something like the rough edges have broken wood grain which doesn't contribute to strength. My gut feeling is either approach is good enough.
PhilBa is online now
Router Bit Woes - HELP! MT Stringer Router Bits - Types and Usage 14 10-24-2013 09:00 AM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 03:22 AM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
Broken bit Mortice Router Bits - Types and Usage 3 02-20-2009 11:51 AM
