Slot-cutter vs rabbet - Router Forums
post #1 of 4 (permalink) Old 12-13-2014, 07:55 AM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Default Slot-cutter vs rabbet
I'm out to buy some new bits. Question: can a 1/4" rabbet do the work of a 1/4 slot cutter? I'm guessing not - just because both are made and bought - but I don't understand why not. Seems like raising the rabbet to the height needed should produce the same result. All advice appreciated.
hankh is offline
post #2 of 4 (permalink) Old 12-13-2014, 09:08 AM
Honored Member
First Name: pat
2 wing slotters (of the same diameter) about as efficient as a 1/4 thick rabbet bit with the same function.
3 & 4 wing slotters are like saw blades.
Note that slotters get big, rabbeters are ~1"D or smaller.
Slotters can get get >2"D & as such are as very efficient but with risk.
As a rule, keep your cutters as small as possible.
Quillman is offline
post #3 of 4 (permalink) Old 12-13-2014, 12:40 PM
You can use either one. I normally use my slot cutters for slotting where I want to join two pieces with a spline but they would rabbet too.
post #4 of 4 (permalink) Old 12-16-2014, 04:42 PM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Thanks for your input. I think that I will start with a rabbet and get a slot-cutter if and when it doesn't meet my needs.
hankh is offline
newbie question freud 58-112 slot cutter lking Router Bits - Types and Usage 3 04-10-2014 08:13 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Locking Rabbet Joints using 1/8 slot cutter swgregory New Member Introductions 5 09-24-2012 10:35 AM
Slot cutter, rabbet cutter or straight bit? crquack Router Bits - Types and Usage 7 12-19-2008 10:42 AM
