tambour door bits - Router Forums
 1Likes
post #1 of 12 (permalink) Old 12-28-2014, 01:12 PM Thread Starter
First Name: JohnN/a
Default tambour door bits
Want to build some bread boxes and have never done the tambour door bit. Is the Amana set best or MLCS set? Consider the price difference too. Will probably only build 6 or 8 of them. Thanks for your help. John
rickey canyon is offline
post #2 of 12 (permalink) Old 12-28-2014, 01:38 PM
I have the Amana bits...
there's folks here that like the MLCS bits but I won't go near them...
which ever you choose there is a lot of tweaking involved...
Rockler has them also....
consider going this way...
Lee Valley Tools - Item Search
Stick486 is offline
post #3 of 12 (permalink) Old 12-28-2014, 02:38 PM
http://www.whitesiderouterbits.com/T...RouterBits.pdf. In this router bit test from 7 years ago MLCS didn't do very well. Rockler did well as did Lee Valley and some others you probably aren't familiar with. The big name maker that scored better than good was Whiteside who won.
post #4 of 12 (permalink) Old 12-28-2014, 04:39 PM
old55's Avatar
First Name: Ross
Welcome to the forum John.
Ross,
old55 is online now
post #5 of 12 (permalink) Old 12-29-2014, 11:14 AM
First Name: Roy
Welcome, John. Glad you're here.
Roy Drake is offline
post #6 of 12 (permalink) Old 12-29-2014, 12:13 PM
TWheels's Avatar
Welcome, John.
I wish I could write from experience. I have the Amana set and I am convinced that they are the way to go. For those not familiar with the Amana set, once cut the slats can assembled into a tambour roll top without any kind of added backing. The MLCS set on the other hand requires a cloth backing after the slats are cut and assembled. The Amana set is designed for pieces that are (at least as far as I know) a nonstandard size; i.e. boards in the recommended size are not readily available off the shelf so they need to cut and planed to the correct size.
I prefer the Amana set because I want the satisfaction of "I built that", and I am a purist. I don't even use glue unless that is the only way whatever I make will stay together. So while it might be more economical to buy the Lee Valley pre-made tambours, where's the fun in that, and besides I intend to push the limits of the recommended sizes when I build the desk I am planning.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
Last edited by TWheels; 12-29-2014 at 12:31 PM. Reason: my D– (with bonus points) in typing class
TWheels is offline
post #7 of 12 (permalink) Old 12-29-2014, 12:20 PM
TWheels's Avatar
Stick, I am somewhat surprised at the vehemence of your statement about the MLCS bits. Why such a strong statement?
Thanks.
TWheels is offline
post #8 of 12 (permalink) Old 12-29-2014, 12:49 PM
Thanks.
vehemence is a bit on the strong side...
brazing failure and the carbide hit me in the ear....
what a mess...
that bit replaced the two that were out of balance...
Stick486 is offline
post #9 of 12 (permalink) Old 12-30-2014, 12:32 AM
TWheels's Avatar
"brazing failure and the carbide hit me in the ear....
what a mess..."
certainly justifies a "vehement" response.
While I have no experience with the MLCS tambour bit I have never had anything like that with any of the other MLCS bits I've used, and nearly all my bits are MLCS.
TWheels is offline
post #10 of 12 (permalink) Old 03-13-2015, 03:59 AM
AUSSIE WOOD's Avatar
First Name: Rendel
I bought an interlocking tambour set from the US a few years ago, it's a 4 step process. The end result is amazing, one guy who writes for one of the Australian Wood Magazines made an outdoor chair using this set.
AUSSIE WOOD is offline
roll top desk tambour template elljay New Member Introductions 5 01-05-2013 08:19 PM
Tambour Projects dunnepet New Member Introductions 2 11-30-2012 06:02 AM
Tambour Doors JPF WOODWORKING Guide Bushings and Templates 2 09-27-2012 07:58 AM
Tambour Desk Project Idea Wood-e Project Plans and How To 6 01-14-2011 11:34 AM
tambour grooves routing problem glencross Portable Routing 6 07-21-2006 12:56 AM
