mortising - Router Forums
post #1 of 11 (permalink) Old 12-29-2014, 12:26 AM Thread Starter
First Name: Stephen
Default mortising
What is the best bit for making mortises.
Keno50g is offline
post #2 of 11 (permalink) Old 12-29-2014, 12:56 AM
Semipro's Avatar
First Name: John_*
Hello Stephen
Welcome to the forum.
Thank You John
Semipro is online now
post #3 of 11 (permalink) Old 12-29-2014, 02:45 AM
Welcome to the forum, Stephen.
I have moved your post to another section of the forum, which may get you more response.
How big are the mortises?
I use a 2 flute straight cutter or spiral cutter.
Make sure the cutter has a end that allows for plunge cutting.
Sydney, Australia
jw2170 is offline
post #4 of 11 (permalink) Old 12-29-2014, 05:47 AM
Country: Estonia
First Name: sergei
a sharp one
:0)
nordbergus is offline
post #5 of 11 (permalink) Old 12-29-2014, 06:15 AM
Hi Stephen and welcome. You can make mortises with a hammer and chisel the old fashioned way, with a router, with a dedicated mortiser, or with a drill press and mortising attachment. I have the drill press and mortising attachment and it works well and was inexpensive.
post #6 of 11 (permalink) Old 12-29-2014, 05:52 PM
old55's Avatar
First Name: Ross
Welcome to the forum Stephen.
Ross,
old55 is online now
post #7 of 11 (permalink) Old 12-30-2014, 12:51 AM
First Name: Ray
Welcome to the forum Stephen!
Charles, what is the drill press mortising attachment you use? Thanx.
RMIGHTY1 is offline
post #8 of 11 (permalink) Old 12-30-2014, 06:38 AM
Bodger96's Avatar
First Name: Bob
Welcome Stephen I use spiral Onsrud bits for most mortises. I agree that you live in the most beautiful of our provinces.
Regards Bob
Bodger96 is offline
post #9 of 11 (permalink) Old 12-30-2014, 12:26 PM
It's made by Delta, Ray and I picked it up at a woodworking show. I have Delta's 16 1/2" drill press and it attaches to the quill in just a few minutes. It also comes with a bushing or adapter for attaching to a different quill size. I think the sizes are fairly standard between the two so I think it will attach to most drill presses. I only paid $60 something for it if I remember right. It comes with 4 sizes of chisels, 1/4, 5/16, 3/8, and 1/2. There is a little trick to setting the bit inside the chisel properly but it's not hard, you just have to pay attention.
You can buy a dedicated mortiser but it takes up a lot of bench space and they cost around $450-500. For a few dollars more you can buy a floor model drill press and the mortising attachment and you'll have a drill press when you aren't using the attachment. The dedicated mortiser will usually also do 5/8 but the attachment will do any size by working both sides of larger mortises.
Lee Valley sells some cone shaped sharpening stones for the chisels and I highly recommend them. I had to sharpen one chisel a while back and just spun the stone in my fingers for a minute maybe and the next cut was like slicing through warm butter.
post #10 of 11 (permalink) Old 01-05-2015, 04:47 PM Thread Starter
First Name: Stephen
Thanks for the welcome. I will try what you have suggested
Keno50g is offline
New DIY Mortising Jig WoodBrewer Jigs and Fixtures 15 10-03-2015 07:28 AM
Router Lift For Mortising davidaz45 General Routing 0 01-31-2012 11:11 PM
Sold: New Delta 17-935 mortising attachment anniekirk Woodworking Classifieds 2 04-18-2011 06:49 AM
End Mills vs.Rrouter Bits For Mortising. Gaia Router Bits - Types and Usage 8 07-03-2010 12:37 PM
Re: router mortising jigs JFB General Routing 7 04-25-2009 08:41 PM
