Using whiteside 6046 window sill bit - Router Forums
post #1 of 13 (permalink) Old 12-29-2014, 06:38 PM Thread Starter
First Name: Kevin
Default Using whiteside 6046 window sill bit
Any advise using this bit would be appreciated. Tried using in homemade table with multiple passes and with a handheld. Low rpm 10,000. A lot of skipping and jumping
This was on red oak. Was going to order a top mounted bearing with locking collar.
Silver7 is offline
post #2 of 13 (permalink) Old 12-29-2014, 06:50 PM
old55's Avatar
First Name: Ross
I can't help Kevin but I'm sure someone will be along to give you some advice.
Ross,
old55 is offline
post #3 of 13 (permalink) Old 12-29-2014, 06:59 PM
skipping and jumping....
sounds like you are trying to climb cut....
feed the stock into the bit...
inverted routers as in a router table it right to left feed...
and don't ever get the stock between the bit and fence...
free hand routing picture shamelessly stolen from another member...
Name:	route direction.jpg
post #4 of 13 (permalink) Old 12-29-2014, 07:37 PM
Semipro's Avatar
First Name: John_*
Agree with Stick, sounds like you are feeding in the wrong direction.
Thank You John
Semipro is offline
post #5 of 13 (permalink) Old 12-30-2014, 11:38 AM
Did you set up featherboards?
Herb Stoops is offline
post #6 of 13 (permalink) Old 12-30-2014, 12:04 PM
He said he was using it in a table.
morrisonc is offline
post #7 of 13 (permalink) Old 12-30-2014, 09:22 PM Thread Starter
First Name: Kevin
possibly I was a bit flustered, giving it another go tomorow
Silver7 is offline
post #8 of 13 (permalink) Old 12-30-2014, 09:54 PM
There really shouldn't be a problem using that bit but it is a little tricky to get a fence set up perfectly for it. The way I find that works best is to use a round dowel that is smaller or equal to the smallest radius of the curve. I turn the bit so that it is 90* to the fence and hold the dowel in the curve and advance the fence until it just touches the rod on both sides of the fence. With bits like this I would prefer the fence to be a little too far back (I'm talking 1/1000ths here) than that much too far ahead of the bit. Sanding the tiny flat off is easy. Trying to hide a dig at the end is harder.
None of that accounts for the jumping. As pointed out you most likely were going the wrong way. Right to left on a table and I only recommend doing this job on a table. You can try using an edge guide but you usually wind up buggering the first couple of inches and the last couple of inches when one side of the guide isn't touching the wood.
post #9 of 13 (permalink) Old 01-05-2015, 04:37 AM Thread Starter
First Name: Kevin
I figured it out I was taking to much material at one time. But where it got difficult again was while using this as a template bit. I got tear out coming back into the grain on both tops I was making. I almost went home for the day!
Silver7 is offline
post #10 of 13 (permalink) Old 01-05-2015, 04:41 AM
was the tear out predominately on the end grain???
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 09:49 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 12:16 PM
Bit for Round Over on Trim for Window coxhaus Portable Routing 4 07-19-2011 09:02 AM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
Router Bit for window mullions? tbwillia Router Bits - Types and Usage 2 10-17-2004 04:42 PM
