Routing in Hickory - Router Forums
post #1 of 8 (permalink) Old 01-20-2015, 02:48 PM Thread Starter
First Name: Doc
Default Routing in Hickory
I'm having a bit of trouble when routing in Hickory. The router is Milwaukee 5616-20, 2 1/4 hp, variable speed. The particular bit I'm have trouble with is a Rockler 22627. Both router and bit are new. Router is mounted to router table with sufficient "hold-downs " and guides. This bit removes quite a allot of material per pass.
Should I be using the highest speed for this very hard wood? I seem to be causing the router to jam and overwork even when feeding slowly. There is also a tendency to shatter or splinter-out. Would you suggest two passes to make to cut?
Any of your suggestions or seasoned advice will be appreciated.
Doc
gregkau is offline
post #2 of 8 (permalink) Old 01-20-2015, 03:48 PM
Doc
or in three passes....
how much are you trying to remove in one pass... all of the required material???
explain jamming a bit more if you will please... you may have dulled your bit...
try a Fred quadra cut or a Whiteside...
there are around 6 or 7 hickories that are most often used... which one are you using???
Hickory is a wood that does splinter easily...
some basic issues w/ Hickory...
Workability: Difficult to work, with tearout being common during machining operations if cutting edges are not kept sharp; the wood tends to blunt cutting edges. Glues, stains, and finishes well. Responds well to steam bending.
post #3 of 8 (permalink) Old 01-20-2015, 04:04 PM
Doc
couple of suggestions...
remove as much material as you can w/ your table saw before you start machining on the router table...
do the cuts in 3 passes... take 90% of the total depth of cut and remove this material in two passes... the last 10% w/ a 3rd pass to complete...
Freud Tools | 2-3/4" (Dia.) Lock Miter Bit
http://www.amazon.com/Whiteside-Rout...N%3DB000K2G56Q
post #4 of 8 (permalink) Old 01-20-2015, 06:38 PM
First Name: Earl
Everything Stick said. And...back up the cut with a piece of sacrificial wood pushed behind your stock. Especially if you're cutting across the end grain.
earl
greenacres2 is offline
post #5 of 8 (permalink) Old 01-21-2015, 12:50 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Everything that has been said is good advice, One other thing thing is that some router cutters, generally the cheaper ones, they are not the same quality as the best cutters and best cutters are sharper and they cut better, I do say that woodworkers should not buy any of the cheaper cutters as they are not value for money, don't buy router cutters sets, those big sets, as they are full of cheap cutters that you will likely never use, so just buy good branded cutters and keep them sharp when they need it, just buy the cutters that you have work for and buy the best brand that you can afford, good cutters are worth spending the money on them to keep them in good nick, and do the other thing. don't take big cuts in one pass, the final cut should be the lightest. I have been trying to buy some Hickory here in Australia but it is not imported here so there seems to be no way to get some and as I was asked to get some for a Billiard cue then it needs top be 1 1/2 square and 5 feet long, and suitable wood for a cue, so not easy to post that, not easy to find out which one of all the Hickory's would be the best one of them to use either, the only way to get the wood here is to buy a sledge hammer that has a Hickory handle and cut the head off it in some type of formal execution, maybe put a hood over its head so it does not see the axe fall, waste of time as there would be no way to find out which Hickory was used for the handle so it would not be the correct one anyway, looks like that Hickory cue is in the too hard basket for a while N
neville9999 is offline
post #6 of 8 (permalink) Old 01-21-2015, 01:21 PM
Pecan is often used as a Hickory substitute...
hickory and pecan usually isn't separated at the mills... when they are they are called true hickory and pecan hickory.
They are in the same genus, just different species.... They are almost always sold as one. The fact is that there are 4 species of true hickory (pignut, shellbark, shagbark and mockernut) and 4 species of pecan hickory (water, bitternut, pecan and nutmeg).
post #7 of 8 (permalink) Old 01-21-2015, 02:49 PM Thread Starter
First Name: Doc
Thank you, I'll reduce the speed and make several passes to accomplish the cut. If unsuccessful, I'll splurge for the Frued bit.
I appreciate all of the responses and sage advice. Doc
gregkau is offline
post #8 of 8 (permalink) Old 01-23-2015, 12:31 AM
First Name: Steve
Default Sharp carbide reduced speed
After several thousand feet of hickory two things are certain, high quality carbide bits and multiple passes are the only chance. Whiteside an Infinity router bits work great. Take a minute to look at grain direction in hickory, it is dense and changes often, thus speed kills. Slow down, nothing's a guarantee with hickory but sharp carbide and slower speed. Happy routing! Amazing results come from hickory!
luckydad is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
