What lock miter bit would you recommend? - Router Forums
post #1 of 16 (permalink) Old 01-23-2015, 08:33 AM Thread Starter
First Name: Dave
Default What lock miter bit would you recommend?
For use in #1 poplar and cedar. I would rather just get one that works the best the first time around and also wondering if any are easier to set up than others. It would be for 3/4" thick boards. Thanks
"It's just a hardened oz or two of metal, sharpened to a razor edge, spinning at 24,000 rpm.....what could go wrong?"
adot45 is offline
post #2 of 16 (permalink) Old 01-23-2015, 09:36 AM
paduke's Avatar
If you are doing only 3/4" material any brand is okay. I prefer Whiteside lock miter bit. Regarding set up there are lots of opinions. Many have a set up block that can be purchased. They are accurate if your material is exactly the same thickness as the block. There are several alternative set ups With some care I scribed a center line between the top and bottom of the cutter on the body of the bit. I align it with a CL on the material There other methods google lock miter for hours of entertainment
paduke is offline
post #3 of 16 (permalink) Old 01-23-2015, 09:45 AM
better known bits like Freud, Whiteside, CMT, Amana etc..
try to stay away from Asian rim...
Stick486 is offline
post #4 of 16 (permalink) Old 01-23-2015, 10:01 AM Thread Starter
First Name: Dave
@ paduke Thanks for the info and I follow what you are saying. If not right on the first time a little bump up or down, forward or backward should make it easy to set. Starting in the ballpark with your method is a big help, thanks.
@ stick Absolutely. And I'm going for carbide as well. OK, I would LIKE carbide....not going to use the car payment for a bit but want it to last a good long while.
Apparently Rocker is watching me type cause I'm being bombarded with their ads for a 45* LMB. But they don't say it is carbide tipped so one could assume it's HSS?
adot45 is offline
post #5 of 16 (permalink) Old 01-23-2015, 10:11 AM
they are watching you...
you need to change your setting in your browser...
do that through properties...
in this day and age I would think HSS bits aren't all that easy to find...
Amazon.com: lock miter router bit
Stick486 is offline
post #6 of 16 (permalink) Old 01-23-2015, 10:20 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
Dave
Might want to check here
Lock Miter Router Bits | Carbide Router Bits
Semipro is online now
post #7 of 16 (permalink) Old 01-23-2015, 11:28 AM Thread Starter
First Name: Dave
Originally Posted by Semipro View Post
Dave
Thanks John, more "grist for the mill" is always appreciated.
adot45 is offline
post #8 of 16 (permalink) Old 01-23-2015, 11:57 AM
Dave if you wanted a HSS lock miter bit you would have to have it specially made. Lock miter bits come in at least 3 sizes for different thicknesses of wood. Make sure you get the one for the range you want to work in. Infinity sells a set up gauge for around $35 I think that works for different thicknesses of wood. I know that CMT's online catalog has a small section in it showing how to set up some of their more difficult bits like rail and stile and lock miters.
In a bit test about 8 years ago Infinity rated better than CMT, Amana, and Freud but not better than Whiteside or Eagle America. Freud bits are good but I don't have the same love affair with them that others do. I have had better performance out of my Lee Valley bits and, in fact, Lee Valley also scored higher than Freud, CMT, and Amana in that bit test.
post #9 of 16 (permalink) Old 01-23-2015, 12:38 PM Thread Starter
First Name: Dave
Thank You Charles, appreciate the info.
adot45 is offline
post #10 of 16 (permalink) Old 01-24-2015, 04:31 AM
First Name: Wayne
Dave
Do yourself a huge favor and get the Infinity lock-mitre jig. It makes setup so much easier than trial and error.
wbrisett is offline
lock miter joint stripper Table-mounted Routing 5 03-20-2014 07:44 AM
Lock Miter Bits Ken Bee Table-mounted Routing 2 07-18-2011 06:44 AM
Lock Miter Bit roedercm Table-mounted Routing 7 07-05-2011 04:28 AM
Lock Miter Bits for Boxes, Your Thoughts on the Better Bit. jhelminski Table-mounted Routing 3 10-08-2010 07:28 PM
Miter lock bits and router tables darren467 General Routing 9 01-01-2009 03:20 PM
