Lock Miter bit size? - Router Forums
post #1 of 10 (permalink) Old 02-01-2015, 12:54 PM Thread Starter
Default Lock Miter bit size?
I know this question has been sort of asked before but I would like to word it a little differently. What I am looking at I have two choices a 2" bit that is for 1/2" to 3/4" stock or a 2-3/4" bit that will work for 1/2" all the way up to 1-1/8" stock. Now the later obviously covers the 2" bit stock size range. I am pretty sure the 2" bit will cover my needs but why wouldn't you buy the 2-3/4" bit to cover all of your possibilities? I do have a router with the hp to handle the larger bit but the only thing I can think of why you may not want to go with the larger is that the 2" bit is a lot easier to handle, I don't have the experience to answer my own question so if someone could help me out I would appreciate it.
bobarue is offline
post #2 of 10 (permalink) Old 02-01-2015, 01:58 PM
The size of the tongue and groove is the biggest factor. At 1/2" material might not have any miter on either side of the T&G.
post #3 of 10 (permalink) Old 02-01-2015, 03:51 PM Thread Starter
Charles,
Bear with me, I'm new to this. I never really looked at this bit as a tongue ang groove but essentially it's a tongue and groove on a 45? Also, you're saying that the tongue maybe at its lower limit on 1/2" stock?
I figured I get a better answer here. I called the manufacturer and all he was worried about was the hp of my router. I guess I wasn't too far off because I basically asked the very question of the answer you just gave me. I asked specifically what the real limits were for each bit as far as the stock size. Well, if you say yes I was right with my understanding of your answer.
bobarue is offline
post #4 of 10 (permalink) Old 02-01-2015, 05:19 PM
Semipro's Avatar
First Name: John_*
Charles is correct it a tongue and groove bit on a 45 angle
I believe that you are too worry about diameter of the bit you really need to be thinking more about the height of the bit.
The bigger bit would verily put a profile on a piece of 1/2" lumber, the same with the smaller bit would not put hardly any profile on a 1 1/2" piece of lumber.
I believe that in most shops the smaller of the two bits would be used 99% of the time
Semipro is offline
post #5 of 10 (permalink) Old 02-01-2015, 10:03 PM
Unless your router is really underpowered the required hp shouldn't be a big issue. You might have to slow your feed speed some is all. Hopefully this link works and will take you and show you Yonico's 3 sizes side by side. You can see that the mid and small sizes are perfectly scaled down versions of the large one.
SET OF 3 Lock Miter 45 Degree Glue Joint Router Bits 15334 | eBay
Don't worry about being new to this, we all were at one time. Keep asking questions as needed.
post #6 of 10 (permalink) Old 02-02-2015, 07:55 AM
paduke's Avatar
Glue Joints - 45 Degree Lock Miter Bits
Charles is right but I suggest a different brand
paduke is offline
post #7 of 10 (permalink) Old 02-02-2015, 10:06 AM
If you are serious about making mitre joints go with the Eagle America or Whiteside (who makes Eagle America). If you think you may only make a few you might want to try Yonico. Most members who have used them are happy with, especially for the price. I wasn't recommending them as much as using them for a reference.
post #8 of 10 (permalink) Old 02-02-2015, 10:32 AM
paduke's Avatar
Whiteside catalog does not show the smaller bit that eagle america has The bits seemed to be manufactured similarly and I have wondered if they were whiteside bits
paduke is offline
post #9 of 10 (permalink) Old 02-05-2015, 10:32 AM
phillipsted's Avatar
First Name: Ted
Another lock miter "newbie" question.
Is it best to use some sort of jig or coping sled when routing lock miter joints? It seems like you'd have problems with snipe or dig-in at the end of the piece as you move it across the to outfeed fence...
TedP
phillipsted is offline
post #10 of 10 (permalink) Old 02-05-2015, 11:29 AM
You should be okay on the horizontal cut but you could use a square push lock to help keep it square which will also help prevent blowout. For the vertical cut if the set up is perfect it should be okay but I have recommended clamping a board to the piece that rides the top of the fence to help. I made a rough Sketchup drawing of what I mean and it's in my uploads along with the link to the thread I did it for.
Wood River Lock Miter Bit hal corbin Router Bits - Types and Usage 4 11-20-2013 12:40 AM
Climb cut on a 45 lock miter bit? Finleyville Router Bits - Types and Usage 13 02-20-2011 11:49 PM
Has anyone used a lock miter bit? dustmaster Router Bits - Types and Usage 29 01-30-2011 07:53 AM
best bit and size for 1" thick drawer edges Elizabeth55 Router Bits - Types and Usage 3 01-18-2010 08:13 AM
Lock miter bit Drick Router Bits - Types and Usage 10 12-28-2005 10:54 AM
