router bits for picture frames - Router Forums
 5Likes
post #1 of 11 (permalink) Old 02-04-2015, 06:25 AM Thread Starter
carl.p's Avatar
Country: South Africa
First Name: carl
Default router bits for picture frames
which bits to use for picture frames. carl
Classical music is food for the mind and soul.
carl.p is offline
post #2 of 11 (permalink) Old 02-04-2015, 08:35 AM
Phil P's Avatar
First Name: Phil
Hi Carl
There are loads of them. Plus you can use two or more in combination. And frames can be made-up by combining two or more pieces of timber. The most obvious starters would be something like cove or ball-nose bits, ovolo or round-over bits and beads. And that's before you start on specialist architrave and picture frame moulding bits. The choice is (seemingly) endless
Regards
Phil
Phil P is offline
post #3 of 11 (permalink) Old 02-04-2015, 12:15 PM Thread Starter
carl.p's Avatar
First Name: carl
Originally Posted by Phil P View Post
Hi Carl
Regards
Phil
Hi Phil I tried to order bits from Wealden but they flatly refused to supply me here in South Africa tried to plead with them but to no avail. carl
carl.p is offline
post #4 of 11 (permalink) Old 02-04-2015, 01:05 PM
Carl if check through my uploads I know I posted 1 or 2 pics of frames. One for sure was made with a 3/8" bullnose and the rest of the profile was with several sizes of ball nose bits just like Phil suggested. I copied a pattern I saw at a framing shop that wanted $25/ft for it. I had a homemade horizontal router setup though and it proved very handy for making frames.
Elite Tools in Canada have a picture frame set and Yonnico (also doing business as Precision Bits) does too. Both are decent quality budget priced bits and they might ship to you.
post #5 of 11 (permalink) Old 02-04-2015, 01:16 PM Thread Starter
carl.p's Avatar
First Name: carl
Default picture frame bits
Hi Chuck thanks for the heads up on those bits will e mail them. regards carl
carl.p is offline
post #6 of 11 (permalink) Old 02-04-2015, 10:03 PM
Phil P's Avatar
First Name: Phil
Hi Carl
It wasn't so much Wealden in particular I was suggesting, more the cutter profiles, which should in the main be found locally (although I don't know the ZA market, so that may not be the case). I Googled "picture frame profiles" and came up with a whole slew of images for picture frame profiles from which it is possible to drill down and dissect the mouldings into individual cutter profiles
There are some fantastic "composite" mouldings on the net made-up from separate pieces of timber (often with a rebate to hide the join) such as this one of weathered cedar, redwood and long leaf pine (outside to inside):
There's also an interesting article on the American Woodworker on using the table saw to make mouldings
I know that the bigger mouldings can require a spindle moulder (shaper) but there are a lot of possibilities (probably too many!) with the router
Regards
Phil
Herb Stoops likes this.
Phil P is offline
post #7 of 11 (permalink) Old 02-05-2015, 02:45 PM
Country: Brazil
First Name: sid
Hi Carl
Take a look at this video, and see if it helps.
How to make a simple picture frame using a woodworking router(Steve Ramsey)
http://youtu.be/RmyytuR-iVE.
regards
ksidwy is offline
post #8 of 11 (permalink) Old 05-30-2015, 09:48 PM
Hi Carl
..... And that's before you start on specialist architrave and "picture frame moulding bits". The choice is (seemingly) endless
Regards
Phil
All those special picture frame bits are 1/2" shank, i have been noticing that majority of the intricate bits are 1/2" shank, is it possible to get them in 1/4", i recently bought a makita 700w 1/4" hand held router. Also is it too difficult to do the intricate style with hand held router, even if it has the assisted bearing.
Thanks guys, i need to make about 200 frames in the quickest / easiest way with out the $$$$
Regards
andreb is offline
post #9 of 11 (permalink) Old 05-31-2015, 01:26 PM
Gaffboat's Avatar
First Name: Oliver
Regards
If you have to make that many frames think about coming up with a simpler design that requires minimal machining.
Gaffboat is offline
post #10 of 11 (permalink) Old 05-31-2015, 03:42 PM
Semipro's Avatar
First Name: John_*
Semipro is online now
Router bits needed for Leigh Dovetail Jig D4R Llewellyn New Member Introductions 11 08-13-2012 03:04 AM
Minimum RPM for Router Bits joprinz CNC Routing 4 12-19-2010 03:52 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
