Reverse/CCW cutting bits - Router Forums
post #1 of 2 (permalink) Old 03-14-2015, 09:29 PM Thread Starter
Default Reverse/CCW cutting bits
I am wondering if there exist any bits that cut CCW. Specifically I am interested in flame-shaped carbide burrs, e.g. SH-7 shaped ones.
Why do I care? Because I am using a flex-shaft to do some free-hand work (mostly on plastic, not wood). I am right-handed, so a normal cutting burr, which requires CW spinning, sends all the chips toward me. Thus, I want to spin the opposite way, which my router can do, but I need a bit for that. Abrasive bits work fine, such as various Foredom ones, but in many cases I prefer to cut rather than grind.
Thanks!
PS: I apologize if this is the wrong place to ask this question! If you know of a better place, let me know!
ORw8xAfu is offline
post #2 of 2 (permalink) Old 03-14-2015, 09:38 PM
you can find what you need at a machine shop supply house...
this company has majorly outstanding customer service, tech support and product knowledgeable people...
call them...
Machinery | Travers Tool
Need advice CNC End mills Vs. router bits SubmarineGuy CNC Routing 8 11-17-2014 07:59 AM
New convert jgregg078 New Member Introductions 8 09-01-2014 05:11 PM
Shank Length vs. Cutting Length (or carbide height) in Straight Bits xzJoel Router Bits - Types and Usage 4 05-12-2012 10:11 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
End Mills vs.Rrouter Bits For Mortising. Gaia Router Bits - Types and Usage 8 07-03-2010 12:37 PM
