Glue joint bits - Router Forums
 1Likes
  • 1 Post By Cherryville Chuck
post #1 of 4 (permalink) Old 04-09-2015, 01:34 AM Thread Starter
First Name: Rob
Default Glue joint bits
Are they supposed to solely be used with a router table or can they easily be used with a hand held router?
WoodCrusher is offline
post #2 of 4 (permalink) Old 04-09-2015, 02:11 AM
I suppose you could use an edge guide and go handheld but you would probably lose about 3" at either end and it would be really tricky to keep the router steady all the way along the length. The router table would be better but the fence has to be set perfectly or you still have problems at the ends.
Have you considered a spline instead? Really easy setup and no wood wasted. You can use a slotting cutter or, depending on the circumstances, a table saw to make the grooves. And you can use the slot cutter handheld.
jj777746 likes this.
post #3 of 4 (permalink) Old 04-09-2015, 02:38 AM Thread Starter
First Name: Rob
If that's the case, I think I'll look into a slotting cutter and use a spline.
post #4 of 4 (permalink) Old 04-09-2015, 03:01 AM
Once you've tried it I think you'll like it Rob. Both joints are basically tongue and groove joints, the spline is a double groove, free floating tongue joint to be specific. Make sure you work from the same face every time and that way those faces will match. If you are doing something like flooring for example, you would want to work from the rear face so that all the backs would sit flush against the subfloor.
The last thing I would suggest is an offset or oversized base for the router. I sometimes use mine in circumstances like this with my router table plate still attached. The extra wide base will give you the stability you need to keep the slot from dipping and diving if doing handheld.
First bit set Mike Router Bits - Types and Usage 46 07-29-2015 08:56 AM
Router bit testing Mike Router Bits - Types and Usage 21 12-17-2014 09:42 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
glue joint router bit aurgathor Router Bits - Types and Usage 12 12-05-2007 12:24 PM
Glue rh111 Lobby 6 10-12-2005 02:30 AM
