How long will a bit last after heating up? - Router Forums
 1Likes
  • 1 Post By fire65
post #1 of 7 (permalink) Old 04-14-2015, 08:03 PM Thread Starter
First Name: Rob
Default How long will a bit last after heating up?
I was using a straight bit doing plunge routing and ended up slightly burning the wood. I probably should have bought a spiral bit for the purpose. Anyway, the router bit got very hot but I don't think it changed color. Question is how much life does the bit have left. It is a Whiteside bit.
WoodCrusher is offline
post #2 of 7 (permalink) Old 04-14-2015, 08:26 PM
You might have been feeding the bit a little too slow. Usually when I burn something that's why. How much life left is impossible to answer. Depends on the woods you rout and technique.
If you are routing pitchy wood clean the bit regularly. That can help.
post #3 of 7 (permalink) Old 04-14-2015, 08:30 PM Thread Starter
First Name: Rob
Yep. I was slow feeding into red oak. So is there any good way to check if the bit is still in decent shape?
post #4 of 7 (permalink) Old 04-16-2015, 12:43 PM
First Name: Otto
The quickest way is to use it again. I doubt very much that the bit is finished. That is why carbide is so popular, it can take lots of heat. Pass it through a piece of scrap and check the finish and how it felt as it went through. There is no way to check it other than microscopic inspection. If you don't trust it, throw it away and get another one.
Otto
otto g is offline
post #5 of 7 (permalink) Old 04-16-2015, 01:41 PM
I realize I didn't read your original post closely enough. Make sure the bit you are using is meant to be plunged. Not all straight bits are. Unless you are plunging a small distance I would drill a starter hole at the least and possibly hog as much waste out by drilling as possible. Most drill bits will remove waste as fast as a router and much more cheaply.
post #6 of 7 (permalink) Old 04-16-2015, 10:54 PM
Shadowrider's Avatar
First Name: Scott
Being a machinist I've seen carbide with steel chips rolling off of it red hot and you'd be amazed at how long they'll last doing that. Like Cherryville Chuck said if your bit is designed for plunge cuts you didn't hurt the carbide. Make sure to clean any pitch off and it's likely not hurt at all.
Shadowrider is online now
post #7 of 7 (permalink) Old 04-17-2015, 08:47 PM
First Name: Clay
Until it gets to dull to cut cleanly.
jw2170 likes this.
fire65 is offline
Safe free hand routing / Building a vacuum bit guard Mike Table-mounted Routing 27 02-28-2015 07:06 AM
Extra long trim bit? Tom Brown Router Bits - Types and Usage 14 08-04-2012 11:45 AM
" shank, " straight bit, extra long mjdtexan Router Bits - Types and Usage 5 12-14-2011 08:17 PM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 03:22 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
