Straight bit to "flush trim" - Router Forums
 1Likes
  • 1 Post By Stick486
post #1 of 5 (permalink) Old 04-19-2015, 02:49 AM Thread Starter
First Name: Rob
Default Straight bit to "flush trim"
Is it possible to use a straight bit with an edge guide instead of using a flush trim bit? I don't have a flush trim bit at the moment so I am looking to improvise.
WoodCrusher is offline
post #2 of 5 (permalink) Old 04-19-2015, 02:56 AM
sometimes..
can you describe your set up and what you are trying to do???
router mounted edge guide or clamp on or straight edge???
post #3 of 5 (permalink) Old 04-19-2015, 03:35 AM Thread Starter
First Name: Rob
sometimes..
I have some oak trim joined and glued to the bottom of a cherry table top. The oak trim is protruding out around 1/16 of an inch. I want to get rid of that 1/16 and make it flush with the top.
I have a router mounted edge guide that I was thinking using.
post #4 of 5 (permalink) Old 04-19-2015, 04:13 AM
risky business to get it perfect...
I wouldn't attempt it w/ anything less than a bit that has a top bearing on it...
for 20 bucks.. why gamble...
Freud Tools
Barry747 likes this.
post #5 of 5 (permalink) Old 04-19-2015, 08:31 AM
First Name: Clay
It is very doable, I trim my solid surface tops like this all the time. I use a 2" straight bit with a straight edge clamped to the top.
fire65 is offline
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
proper straight bit size for dadoing coupe Router Bits - Types and Usage 4 03-09-2009 10:31 AM
