Fly Cutting Bit? - Router Forums
post #1 of 5 (permalink) Old 04-25-2015, 09:02 AM Thread Starter
The Hobbyist's Avatar
First Name: Joe
Default Fly Cutting Bit?
Hi, I am looking for a wide bit to use, to fly cut a sheet of MDF on a CNC table so that the surface is level with the rails. I found a bit that is 1-1/8" wide with a flat bottom. it works okay, but I am looking for something wider ... maybe 1-1/2" to 2" wide??? 1/2" shank.
Any links or help will be appreciated.
The Hobbyist is offline
post #2 of 5 (permalink) Old 04-25-2015, 09:18 AM
Dado & Planer Router Bits | Carbide Router Bits
http://www.carbideprocessors.com/rou...r-router-bits/
post #3 of 5 (permalink) Old 04-25-2015, 10:07 AM
First Name: Phil
What I am used to seeing called "fly cutters" are made for use on the drill press. They would be dangerous at the speed generated by a router.
Phil
Phil Dalton is offline
post #4 of 5 (permalink) Old 04-26-2015, 02:46 AM Thread Starter
First Name: Joe
THANK YOU Stick486! That is exactly what I was looking for!
post #5 of 5 (permalink) Old 04-29-2015, 07:01 AM
First Name: Allen
Also check out the following:
- Onsrud Surfacing Cutter
- Magnate Surface Planing ( Bottom Cleaning ) Router Bit , 2 Flute Carbide Tipped
I can't yet post links on this site so I just mention the bits; you can google search them. The Magnate gets a very good review:
" I do a lot of router sled planing of large hardwood slabs, 1 to 2 per month on average. After trying numerous bits I settled on the Magnate 2706 Bottom Cleaning Bit ( 2" cutting diameter, 3/4" cutting length with a 1/2" shank) in a PC 890 (2 1/2 HP) running at 16,000 RPM. This bit really does a solid job but be aware that upon completion of the planing process there will still be a need to sand out the tiny ridges, more like registry lines, that one gets with any bit in this process. Magnate seems like a solid company; wide selection, reasonable prices, quick shipping, good people and the bits outlast any of the others I have tried." (from Sawmill Creek.org site)
Also, check out lumberjocks.com/topics/1992.
aganser is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Bit for cutting aluminum mickelsen Router Bits - Types and Usage 10 11-07-2011 08:56 AM
Thread cutting bit wvcowboy Router Bits - Types and Usage 2 09-14-2011 10:04 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Tenon cutting Router bit iamwelty2 Table-mounted Routing 11 05-01-2010 11:49 AM
