Aluminum Bits - Router Forums
post #1 of 3 (permalink) Old 05-17-2015, 12:49 PM Thread Starter
First Name: Philip
Default Aluminum Bits
What is the best aluminum bit for cnc router?
Thank you,
Philip
Dukie94 is offline
post #2 of 3 (permalink) Old 05-17-2015, 02:50 PM
Thank you,
Philip
I take it you mean a bit for cutting aluminum, not an aluminum router bit
Toolstoday.com - Aluminum Cutting CNC Router Bits
Try this link, they seem to be pretty well versed in supplying cnc customers. I think an O flute is recommended but I don't cut aluminum.. at least not yet. I have got a couple of O flutes I use on plastics and they do a great job there.
John Schaben
jschaben is offline
post #3 of 3 (permalink) Old 05-17-2015, 03:21 PM
Billy Hill's Avatar
First Name: Will
It all depends on what you're doing, what you're doing it on and how you're holding it.
The tools for cutting plastic are worlds apart from tools for cutting metal. The blunt angles on metal cutting tools will chip and break plastic, and the sharp angles of plastic cutting tools will wear very quickly in metal. That's not to say you can't use metal cutting tools on plastic, but you'd be hard pressed to have success cutting metal parts with plastic cutting tools.
Typically you would want to use 2 flutes on alum and always use cutting fluid or some kind of lubricant. (Lubing the cutter to prevent welding is more important than heat removal on this kind of machine.) Using 4 flutes often provides better finishes but it's difficult to rough with them. Light cuts on a router might lend itself nicely to using 4 flutes. Hi spiral bits would help reduce tool pressure, provide better chip removal and leave a nice finish even under stressful conditions.
The (lack of) rigidity of the router is going to make it difficult to get a good finish and hold close tolerances so a good understanding of toolpath approach and the difference between conventional and climb cutting will go a long ways. I have not tried to cut metal on my router yet but once I get a better table/bench for it I will then I will be able to give you more informed advice.
For alum the surface speed is much more important. Too much and you get chatter and a bad finish, too little and you break the tool or keep picking your work up off the floor (depending on your workholding method). Again, the light cuts you'll be taking on a router will help negate some of this effect.
Give a little more info on what you're trying to do and I'll give you what ever advice I can.
Instead of seeing things and asking "why", envision things and ask "why not"
Billy Hill is offline
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Metric and Imperial Routing Bits awhitecat General Routing 17 11-28-2014 06:10 PM
Need advice CNC End mills Vs. router bits SubmarineGuy CNC Routing 8 11-17-2014 07:59 AM
Insert router bits subtleaccents Router Bits - Types and Usage 0 02-18-2014 08:59 AM
Rate your personal experience with router bits ... riffin-rich Router Bits - Types and Usage 36 05-23-2011 07:43 AM
