Raised Panel Bit Multiple Cuts - Fence Out or Bit Up? - Router Forums
 1Likes
  • 1 Post By Stick486
post #1 of 9 (permalink) Old 05-21-2015, 08:26 AM Thread Starter
First Name: JT
Default Raised Panel Bit Multiple Cuts - Fence Out or Bit Up?
In making multiple passes with raised panel bits (using a table) so as not to take too much material at once, I'm curious what most folks do:
- Start with final fence adjustment; bit lowered and raise bit on subsequent cuts
or
- Start with final bit height adjustment; fence "in" and adjust fence "out" on subsequent cuts
I'm running an Incra LS positioner with a Master Lift II, so either method is pretty manageable / repeatable.
Thanks!
Rufnek100 is offline
post #2 of 9 (permalink) Old 05-21-2015, 08:32 AM
or
Thanks!
either or...
depends on the profile...
bit raised and move the fence is preferred relying on the bearing(s) to control final cut...
Herb Stoops likes this.
post #3 of 9 (permalink) Old 05-21-2015, 08:48 AM Thread Starter
First Name: JT
Thanks - that's what I did last time (being a hobbyist I don't make a plethora of cabinet doors), but got to thinking about the other method and wondered if there was a "proper" universally accepted way of doing it. I couldn't really come up with a strong reason in my mind why one method would be superior to the other.
post #4 of 9 (permalink) Old 05-21-2015, 01:11 PM
Semipro's Avatar
First Name: John_*
Jt I usually set the depth and move the fence
Semipro is offline
post #5 of 9 (permalink) Old 05-22-2015, 07:42 AM
First Name: Art
The panel bit that I use doesn't have a bearing, I set the fence and raise the bit until I get to the desired height. I just find it quicker this way.
mgmine is offline
post #6 of 9 (permalink) Old 05-22-2015, 08:43 AM
For some who have adjustable fences on their tables they set everything for the final pass and then put a set of shims behind the fence faces, pulling out a shim per pass.
post #7 of 9 (permalink) Old 05-22-2015, 11:13 AM
First Name: Clay
I move the fence and use a vertical raising bit.
fire65 is offline
post #8 of 9 (permalink) Old 05-22-2015, 11:35 AM
I do it both ways, depending on the profile I am cutting
Herb Stoops is online now
post #9 of 9 (permalink) Old 05-22-2015, 05:56 PM
I'm with Herb. If you are using a bit with an undercutter, you haven't much choice.
John Schaben
jschaben is offline
Which Raised Panel Bit Set Lowcountrygamecock Table-mounted Routing 11 08-07-2013 07:54 AM
Mitered raised panel doors bobj3 Table-mounted Routing 13 09-03-2010 12:37 PM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
raised panel bit set vjeko Router Bits - Types and Usage 5 04-01-2009 08:16 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
