Bit to buy ? - Router Forums
 13Likes
post #1 of 15 (permalink) Old 06-12-2015, 03:10 PM Thread Starter
First Name: Richard
Default Bit to buy ?
I will be using a Craftsman 171.25444 Router Table with a Craftsman 315.17460 Router.
I need to pot a "notch" in one edge of a standard Doug Fir KD 2x4 ( 1 1/2" x 3 1/2" )
I want the notch to be 1/4" deep by 3/4" wide along the 1 1/2" side. I will be doing this to pieces approx. 2ft long and there will be a good number of them.
VERRY much a novice and don't have a clue as to which bit to use. Would prefer to do it in just one pass.
Thank you !!
dicynd is offline
post #2 of 15 (permalink) Old 06-12-2015, 05:47 PM
Thank you !!
First, welcome to the form.
The router you are using is most likely takes a 1/4" diam. shank bit, so I would recommend a 3/4" diam. straight bit.
Set up the fence center of the bit, this will give you a 3/8" wide cut and raise the bit 1/4". Make that cut, then move the fence 3/8" more away from the center of bit and make the last cut.
I am not sure which way you are making the cut, but this will work if it is on the flat or on the edge..
Herb Stoops is online now
post #3 of 15 (permalink) Old 06-12-2015, 08:27 PM
Richard, any straight cutting bit that is 1/4" diameter or larger will do the job in multiple passes. To avoid tear out use a backer board to support the wood. You can also make the simple push block shown with a piece of 1"x4" (or larger) and a shaker peg for a handle. You can rotate this push block once you can no longer use the edge and make use of the other 3 edges before replacing the block.
Herb Stoops likes this.
post #4 of 15 (permalink) Old 06-12-2015, 11:22 PM
Hey, Richard;
Two passes with your TS. One for the width and the second for the depth.
Make sure the small offcut falls away from the blade...not trapped between the fence and the blade. And don't stand behind the blade.
The router will do a prettier job but it'll take you way longer.
Shop guy and Herb Stoops like this.
DaninVan is online now
post #5 of 15 (permalink) Old 06-13-2015, 07:38 AM
First Name: Art
I agree with the table saw, You can do it with the router easy enough but the table saw is just as easy and no need to buy a bit. However if you don't have one this would be a reason to buy a straight bit and start building up your collection.
mgmine is offline
post #6 of 15 (permalink) Old 06-13-2015, 10:31 AM
Being a newbie with the router, I would not recommend trying to hog off the whole thing in one pass with a router. As stated above a table saw is the tool of choice, but it will take 2 passes for that also, unless you have a dado or box cutter blade then you could do it in one pass on the ole table saw.
It would be a good idea to use horizontal and vertical feather boards on the router table too,to hold the stock down and tight to the fence, along with a push block.
post #7 of 15 (permalink) Old 06-14-2015, 08:30 PM Thread Starter
First Name: Richard
Thanks to all who replied !!
I don't have a table saw BUT do have a Radial Arm Saw that I could do similar cut with just "up side down" but she has been around the block since I bought her in 1977 ( + - ) My "boys" knocked her off the bench and onto the floor and she has never quite been ( if she ever was ) a precision tool since.
I "have" the router and thought I would give it a try. I'm working on "ruff stock" -- a 2x4 right off the floor at a big box store. the boxes that I am making are made to look "rustic" so "fit and finish" isn't much in the equation >
Name:	Cul Whl 01Fin.jpg
Name:	Cul Whl 05Fin   ( Minneapolis Moline )RED-E-MOTION at BB 3-13-13 $285.jpg
dicynd is offline
post #8 of 15 (permalink) Old 06-14-2015, 09:03 PM
From what you say, I would not attempt the RA saw either, even if it was in good shape,and then only as a last resort. THe router is the way to go, preferably in a router table. Just make a safe set up and take more than one pass. Do all of them on the first set up, then move the fence and do the second cut on all of them.
What is that you are making, it looks interesting.
post #9 of 15 (permalink) Old 06-15-2015, 12:35 AM
no doubt about that....
post #10 of 15 (permalink) Old 06-15-2015, 10:57 AM Thread Starter
First Name: Richard
For those of you who don't know "what" these are ! They are Rotary Hoe Wheels from farm implements. They come in an array of types and sizes.
I am a 70yo retired "city boy" from Seattle now living in Tucson, Az.. I saw my first one of these last August in an antique mall and thought that there might be something that I could "do" with it :--) It started as JUST a hobby then friends suggested that I show them at an "Art Show" and now they are calling me an "artist" which is much better that what some people have called me :-).
I have made about 35 different ones and currently have approx. 150 loose wheels in reserve of which 75 are different from one another.
A local craft beer brewery asked me to display some in their tasting area which is a very old converted open beamed farm equipment whse. next to the main railroad line through town. They are very appropriate for the setting. They are for sale there BUT I'm happy if they don't sell !! Don't want it to become a business -- want it to STAY a hobby :--)
IF anyone would like to see more pic's I have posted some on a Facebook account --- farm2art-tiques --- !!
Name:	Borderlands Art 03 Displayed 3-25-15.jpg
Name:	Cul Whl 54Fin.jpg
dicynd is offline
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
Anyone buy a router bit from Oak Park? tpyke Router Bits - Types and Usage 4 01-07-2008 11:39 PM
