22 1/2 deg. Lock Miter - Router Forums
 3Likes
  • 2 Post By Stick486
  • 1 Post By Herb Stoops
post #1 of 3 (permalink) Old 06-20-2015, 04:10 PM Thread Starter
Default 22 1/2 deg. Lock Miter
I see where Freud has a 22 1/2 degree lock miter bit for those making octagon boxes and planters.
Buy Freud 99-043 Lock Miter Router Bit 1/2" Shank 22-1/2 Degrees 7/8" CL at Woodcraft.com
Herb Stoops is online now
post #2 of 3 (permalink) Old 06-21-2015, 12:12 AM
thanks Herb.. good to know...
here's another multisided bit... this one from LV...
Bird's-Mouth Joinery Bits™ - Lee Valley Tools
MYB and Herb Stoops like this.
post #3 of 3 (permalink) Old 06-21-2015, 01:24 PM Thread Starter
Yeah thats the ole birdsmouth bit that has always been the standby. I had not seen a lock miter for 22 1/2 deg. before, might be fairly new, and from my favorite bit manufacturer too.
The advantage with the LV bits is that one bit will make the cut,whereas the Freud takes 2 bits and it is only for 8 sided and the LV for 6-12 sided with 3 bits.
Stick486 likes this.
Power miter saw moves when tighten table lock jmoore65 Tools and Woodworking 5 06-22-2014 09:36 AM
Larger Lock Miter Bits Available? gcristof Router Bits - Types and Usage 4 05-13-2014 05:16 AM
lock miter bit grimreeper General Routing 1 09-17-2011 12:41 PM
Climb cut on a 45 lock miter bit? Finleyville Router Bits - Types and Usage 13 02-20-2011 10:49 PM
Lock miter bit Drick Router Bits - Types and Usage 10 12-28-2005 09:54 AM
