Upcut Downcut - Router Forums
 7Likes
post #1 of 20 (permalink) Old 08-15-2015, 12:11 PM Thread Starter
Default Upcut Downcut
Can someone give me a beginner's explanation of when to use an upcut and when to use a downcut bit? For starters, am I correct that upcut moves the sawdust towards the router?
Sam Blount likes this.
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 20 (permalink) Old 08-15-2015, 12:14 PM
vindaloo's Avatar
First Name: Angie
Upcut pulls the chips towards the router so use if it's a blind hole/slot
Downcut pushes chips away so use for through slot or trimming.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #3 of 20 (permalink) Old 08-15-2015, 12:14 PM
RainMan 2.0's Avatar
Mike I want to see if I remembered . An uncut bit forces the wood out evacuating the hole better out of the material , but for laminate you want a down cut as it would have less of a chance of chipping the melamine etc.
let's see how close I am lol
Ok I posted a few seconds to late and got beat
fire65 and timbertailor like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 20 (permalink) Old 08-15-2015, 12:20 PM
tes on the saw dust removal...
see if this helps...
firstmuller likes this.
post #5 of 20 (permalink) Old 08-15-2015, 12:27 PM Thread Starter
And here goes the confusion. Angie says, "Upcut pulls the chips towards the router so use if it's a blind hole/slot". The PDF that Stick posted says, "DOWNCUT Bits (naturally) cut downward (away from the router base). This motion gives grooves, dadoes, rabbets, shallow mortises and plunge cuts a smooth clean edge. REMEMBER: Downcut bits push sawdust into the cut. Making multiple passes reduces the buildup of sawdust in the groove."
Wouldn't a dado be a slot? It seems that these two recommendations are at odds with each other, and Angie's recommendation makes more sense to me.
patlaw is offline
post #6 of 20 (permalink) Old 08-15-2015, 12:39 PM
vindaloo's Avatar
First Name: Angie
If you use a downcut to cut a dado (non-through slot) the corners are not raised by an upcut, so are smootherwith less to no whiskers. The problem that can occur is sawdust buildup in the slot.
vindaloo is offline
post #7 of 20 (permalink) Old 08-15-2015, 12:47 PM
vindaloo's Avatar
First Name: Angie
@patlaw
Mike you could always get an upcut-downcut bit (called a compression bit), best of both worlds. They do seem to be a little on the expensive side for a hobbyist like me though
vindaloo is offline
post #8 of 20 (permalink) Old 08-15-2015, 12:54 PM
It was so nice and easy when everyone could see all the sticky threads on the main menu.
Hope this helps people.
http://www.routerforums.com/router-b...tml#post505441
Nickp likes this.
post #9 of 20 (permalink) Old 08-15-2015, 02:19 PM
Nickp's Avatar
First Name: Nick
An upcut makes a cut towards the router, the downcut away...
Upcut clears sawdust in a blind slot, downcut makes a clean edge on the face closest to the router, upcut makes a clean edge on the face away from the router.
...so which way do you want the sawdust to go and which face do you want cleanest...both are allowed...
Compression bits clean both ways and leave a clean cut on both faces (if aligned properly and through-cut)...they come in different lengths...
Downcut in a mortise will give you a clean cut but will not clear sawdust very well...bit will heat up faster...Upcut will clear the sawdust, leave a bit of fuzz but can be sanded and hidden by the shoulder of the tenon... (eeeuwww)...everybody hides bellybutton fuzz...
...it's up to the imagination...
...did ya learn me right, roomies...?
vchiarelli likes this.
Nick
Nickp is online now
post #10 of 20 (permalink) Old 08-15-2015, 02:21 PM
Nickp's Avatar
First Name: Nick
...change is inevitable..."resistance is futile"...
It used to be "ars gratia artis"...nowadays it's (tech gratia techis)
Nick
Nickp is online now
Quick Question:spiral bit, upcut or downcut? p3auul Router Bits - Types and Usage 17 02-04-2013 01:50 PM
for those who cant afford spiral upcut bits... Mike Gager General Routing 21 12-08-2012 04:00 PM
upcut vs downcut spiral Skyewalker Router Bits - Types and Usage 7 09-10-2012 05:00 AM
Upcut versus downcut spiral bit rharveyva Router Bits - Types and Usage 6 07-19-2011 01:12 AM
Upcut or Downcut for Box Joint? Bran Name? RJM60 Router Bits - Types and Usage 19 06-12-2010 04:59 PM
