Round Over Bit question - Router Forums
 7Likes
post #1 of 20 (permalink) Old 08-16-2015, 09:00 PM Thread Starter
First Name: Rob
Default Round Over Bit question
Hi everyone. I'm new to the forum and kinda new to using a router. I mostly use a scroll saw. I have always loved what a router can do and finally picked up one with a table to work with. I have a question about a round over bit I have. I have it set in my table and I was practicing on some scrap wood I have and all went well, except I noticed that it leaves a 'lip' of sorts on the top of the rounded over part. It looks nice, but that is not the look I was going for. I just wanted a plain rounding over of the edges.
Do I have the bit to high? To low? Or am I doing something else totally wrong? As I'm just learning what I am doing, I know I am making a million mistakes but I am enjoying using the router. Any help would be appreciated.
Thank you!
Rob
Robh22 is offline
post #2 of 20 (permalink) Old 08-16-2015, 09:02 PM
MT Stringer's Avatar
Tweak your height and test again. I do that every time I use a roundover bit.
MT Stringer is offline
post #3 of 20 (permalink) Old 08-16-2015, 09:25 PM
in a router table the bit is set too high...
if were in a free hand router it would be set to low...
play w/ the setting...
learn to do it by eye...
DaninVan and Herb Stoops like this.
post #4 of 20 (permalink) Old 08-16-2015, 09:42 PM
First Name: Ray
Stick is dead-nuts on!
Ray Newman is offline
post #5 of 20 (permalink) Old 08-16-2015, 09:51 PM
A roundover bit can make two different cuts depending on the size of bearing. If the bearing is the same size as the bottom end of the cutter then you get the roundover. Use a smaller bearing and you get a profile instead (like a roman ogee for example). If you are using it to make a profile then you want that edge you are talking about.
post #6 of 20 (permalink) Old 08-16-2015, 09:55 PM
Rob, you can make adjustments easier with some brass set up bars. I will take some photos showing how easy they make it. I had some old photos of this but the quality wasn't that good so it is time for new ones.
TWheels and WigWag Workshop like this.
post #7 of 20 (permalink) Old 08-16-2015, 10:11 PM
another think...
if your board isn't flat that shoulder will be irregular despite all the careful adjustment in the world...
DaninVan and MT Stringer like this.
post #8 of 20 (permalink) Old 08-17-2015, 01:17 AM
Hey, Rob; welcome!
All of the above, especially the playing with the ht. adj. on a piece of scrap.
Fair warning, watch out for hidden nails on previously used wood...router bits don't like that at all!
DaninVan is offline
post #9 of 20 (permalink) Old 08-17-2015, 07:10 AM
Nickp's Avatar
First Name: Nick
A bigger bit will give you a different effect on the piece by positioning it to a different spot on the bit...higher closer vs lower further...
Play with different sizes and different positions...
Welcome...
Nick
Nickp is offline
post #10 of 20 (permalink) Old 08-17-2015, 07:53 AM Thread Starter
First Name: Rob
Thank you everyone. I really do appreciate all the help. I so wish there were places around here that have classes, as I want to learn as much as I can. It's the same with scroll saw work, I want to learn Intarsia, but there are no classes. I really love all all the things a router can do and want to get the most out of it. I watch a ton of You Tube videos but you can't ask a video a question.
Thank you all again. I will try all your suggestions.
Robh22 is offline
Tapered round nose bit. davidjonah New Member Introductions 8 02-10-2014 08:32 PM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Question about rabbeting bit sets LBrandt Router Bits - Types and Usage 2 07-19-2009 05:07 PM
Bit for jointing question dabeeler Router Bits - Types and Usage 11 11-13-2007 10:57 AM
