MuscleChuck - First impression - Page 3 - Router Forums
 26Likes
post #21 of 28 (permalink) Old 06-05-2019, 12:59 PM
kp91's Avatar
First Name: Doug
Originally Posted by harrysin View Post
I've never heard of a MUSCLECHUCK being the cause of vibration, all the cases that I've come across turned out to be from other causes. Are there any members who have a MUSCLECHUCK/s and is unhappy with it?
Harry,
most of the 'problems' with the musclechucks are people not following the directions. If you just put the chuck on, there may be run-out. Joe shows you how to address it in the video. If you put a 1-1/2 inch surfacing bit in when there is 0.020" run-out, you will know it the second you fire it up Trust me. After adjustment, silent as a lamb.
harrysin and Gaffboat like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #22 of 28 (permalink) Old 06-05-2019, 01:55 PM
JFPNCM's Avatar
First Name: Jon
I’ve been using one in my table on PC motor for longer than I care to remember and no issues.
Herb Stoops likes this.
Jon
JFPNCM is offline
post #23 of 28 (permalink) Old 06-05-2019, 03:42 PM
Gee Doug, I don't even have one of those funny looking wristwatches on a stick. I just installed the MC out of the package and ran with it, I must just be lucky>LOL
kp91, jw2170 and JFPNCM like this.
Herb Stoops is offline
post #24 of 28 (permalink) Old 06-05-2019, 04:05 PM
kp91's Avatar
First Name: Doug
Grab a budget one from HF when they go on sale. Lots of uses in the shop. You don't need the fancy stands, you can make your own out of scrap hardwood. They show more than what your eyeballs can easily see!
I have made jigs for aligning the Table saw, squaring jointer tables, etc. The CNC needs a little adjustment every so often, it really comes in handy there.
I think every shop should have feeler gages ($5), a dial caliper ($15), a good machinist square ($40, or a cheap one for $10) and dial indicator ($15). I have nice ones for my profession, but 90% of the time I use the HF ones and keep my good stuff safely tucked away. I have compared a lot of the cheap units, and they are surprisingly accurate, especially for a home wood shop.
They make great stocking stuffers, just tell your loved ones what to buy!
https://www.harborfreight.com/1-in-t...dial+indicator
jw2170 and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #25 of 28 (permalink) Old 06-05-2019, 05:16 PM
You can over tighten them onto the arbor and throw them out of balance too. V O E speaking.
JFPNCM and Herb Stoops like this.
post #26 of 28 (permalink) Old 06-05-2019, 06:57 PM
Thanks,Doug, that looks like a mech. one, no battery, I like that.
post #27 of 28 (permalink) Old 06-06-2019, 10:19 AM
Honored Member
harrysin's Avatar
First Name: Harry
An excellent video Doug, I hadn't seen it before. This is a shot from a series of tests that I carried out quite some time ago with similar results. I'm still waiting to hear details of complaints.
jw2170 likes this.
Harry
harrysin is online now
post #28 of 28 (permalink) Old 09-07-2019, 01:48 AM
BCR
The bearing itself may be out of round, that is a bad spot to take readings. You would be better off taking out the bearing and just using screw threads. Just saying, as I have thrown a lot of bearings out from wear.
BCR is offline
Musclechuck Ken Bee General Routing 28 07-20-2015 12:28 PM
MuscleChuck vs Whiteside Eliminator...huh...? Nickp Router Bits - Types and Usage 38 06-09-2015 11:40 PM
Musclechuck N'awlins77 Jigs and Fixtures 28 02-13-2015 07:39 AM
At last, a MUSCLECHUCK for the early TRITON routers harrysin Lobby 1 06-07-2014 01:18 AM
Installing a Musclechuck Mike General Routing 6 04-26-2014 02:20 PM
