smaller than 1/8" flush trim? - Router Forums
post #1 of 10 (permalink) Old 10-05-2015, 12:57 PM Thread Starter
bobditts's Avatar
First Name: Bob
Default smaller than 1/8" flush trim?
Does anyone make a flush trim bit smaller than 1/8" diameter? or is it just impractical?
Follow me on Instagram at #bobditts
bobditts is offline
post #2 of 10 (permalink) Old 10-05-2015, 01:29 PM
they are called burrs if there is one out there...
look to a rotozip cutter...
post #3 of 10 (permalink) Old 10-05-2015, 01:41 PM Thread Starter
bobditts's Avatar
First Name: Bob
Thanks for the lead sticks. Unfortunately Im not having any luck finding burrs that flush cut. Any chance someone can assist in locating one?
bobditts is offline
post #4 of 10 (permalink) Old 10-05-2015, 02:01 PM
Ghidrah's Avatar
First Name: Ronald
I'd say too brittle and or flexible for lateral stress. Route a smidge too vigorously with an 1/8" bit and you can junk it.
May I ask what it is you're doing that would require a 3/16 diam. or less bit?
Ghidrah is offline
post #5 of 10 (permalink) Old 10-05-2015, 02:23 PM Thread Starter
bobditts's Avatar
First Name: Bob
I kinda figured that. I am trying to duplicate a sign out of 1/8" thick mdf or ply. The sign spells out the phrase "merry christmas" It has some tight inside edges that I dont think a 1/8" bit would catch. Id rather not have to scroll new ones everytime and I dont want to go the laser route. Just trying to find the easiest way to mass produce these.
bobditts is offline
post #6 of 10 (permalink) Old 10-05-2015, 02:45 PM
SteveMI's Avatar
First Name: Steve
I use smaller diameter end mills with a CNC, you really need to control speed and feed which a CNC will let you do. Hobbyist got some 1/16" bits with 1/4" shank. See post http://www.routerforums.com/cnc-rout...s-arrived.html
My smaller ones have an 1/8" shank for use in ER collets.
Steve.
SteveMI is offline
post #7 of 10 (permalink) Old 10-05-2015, 03:00 PM
a burr and MDF are pretty much incompatible...
thin MDF is primarily waste paper and glue...
look to luan door skins and stack cut them...
look to burrs and use the shank as the bearing/guide...
Burs for Carving | Burs | Carbide Burs | Rotary Burs |Wood Carving
Miniature Carbide Burs
look to a piloted zip bit..
RotoZip Bits:ZipBits,XBits and XCores
post #8 of 10 (permalink) Old 10-06-2015, 08:41 AM
Garyk's Avatar
First Name: Gary
Hope this is not a duplicate, my post did not show up.
Try Amana, they make a set of miniature bits.
Garyk is offline
post #9 of 10 (permalink) Old 10-06-2015, 08:51 AM Thread Starter
bobditts's Avatar
First Name: Bob
thanks for all the replies everyone. For now I have decided just to get an 1/8" flush spiral bit (link below). It will get most of my job done with minimal follow up scroll saw work. I will follow the leads you all mentioned for a better solution down the road. Thanks again! This forum rocks!
SPFT.125 1/8" Solid Carbide Spiral Flush Trim Bit - 12vTools
bobditts is offline
post #10 of 10 (permalink) Old 10-06-2015, 10:58 AM
MEBCWD's Avatar
why not adjust the pattern so the 1/8" bit with fit between all the letters then you can cut them over and over without having to revert to the scroll saw for cleanup. or as stick says stack cut them with the scroll saw
MEBCWD is offline
I need help with choosing a double bearing flush trim bit tdale Router Bits - Types and Usage 19 03-08-2012 06:31 AM
Pattern Bit or Flush Trim? Harris Router Bits - Types and Usage 1 06-15-2010 12:50 PM
Flush trim bit not flush RuggerJoe Router Bits - Types and Usage 8 03-19-2008 12:57 PM
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 01:51 PM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 08:39 AM
