Slipping bit - Router Forums
 5Likes
  • 1 Post By Stick486
  • 2 Post By Cherryville Chuck
  • 1 Post By Semipro
  • 1 Post By Nickp
post #1 of 10 (permalink) Old 11-25-2015, 08:15 PM Thread Starter
First Name: Kerry
Default Slipping bit
Can anyone offer a suggestion please, my table mounted TRA001 Triton slips when using the collet and smaller bits? Without the collet and using the large bits we're all good, no slippage.
I also have a handheld Ryobi router and thought I may have mixed up collets. That was not the case I'm using the original Triton collet.
I've searched the forum but not found anything specific to this problem and this router, any suggestions please gents?
Kerry
Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
-Walter Blodget
Larkan is offline
post #2 of 10 (permalink) Old 11-25-2015, 08:26 PM
did you mix up SAE/Metric bit shanks and collets...
done maint on your collet lately????
Larkan likes this.
post #3 of 10 (permalink) Old 11-25-2015, 08:50 PM
"Without the collet and using the large bits we're all good, no slippage."
By that statement I think you are using a reducer bushing for the 1/4" shanks? First question is has it always slipped or did it just start? If it has always slipped then toss it and get a different one. If it just started slipping then it needs cleaning according to Stick's link or it is worn out. Check the mating surfaces of bushing to bit and make sure it isn't galled from wear and heat from the slippage. If it is you definitely need a new one. I think there is a Musclechuck to fit that router and it should provide a better grip than your regular collet.
Larkan and Semipro like this.
post #4 of 10 (permalink) Old 11-25-2015, 11:34 PM
Semipro's Avatar
First Name: John_*
I believe Stick and Chuck are correct.
Blue is a Sleeve
black is the nut
red is the collet
the sleeve probably is shot , replace it and the router bit it's been spinning probably scored now.
Larkan likes this.
Semipro is online now
post #5 of 10 (permalink) Old 11-26-2015, 01:19 AM Thread Starter
First Name: Kerry
Thanks gents just in from the shed and have read through these comments and suggestions inc Sticks maintenance & Guide pdf's
I plan to check out my collet and set up in the next few days so will give you the results in due course.
Many thanks
Kerry
-Walter Blodget
Larkan is offline
post #6 of 10 (permalink) Old 11-26-2015, 07:54 AM
Nickp's Avatar
First Name: Nick
A very close inspection of the mating surfaces is important...
My Triton's 1/2 inch collet had created a small burr on the router spindle mating surface...apparently it pinched it with the closing surfaces of the collet. It worked fine with 1/2 in bits as it lined itself up precisely each time... When I used the 1/4 collet it did not line up and therefore did not close properly.
It took a magnifying glass and light to find it...
Not saying you have the same problem...just a reminder that our eyes can trick us.
Larkan likes this.
Nick
Nickp is offline
post #7 of 10 (permalink) Old 11-26-2015, 12:13 PM
bcfunburst's Avatar
First Name: Reg
Default Bit Slippage
I also use a TRA001 for many years now. I finally switched out my collet system for a MUSCLECHUCK. It works amazingly well for 1/2" and 1/4" bits, with NO slipping, as long as I blow out the chuck each time with a short blast from the air hose, and inspect the bit and shaft EVERY TIME!!! There IS a MUSCLECHUCK for this router too. It only takes one mistake to ruin your fine wood or injure YOU. BE SAFE!! PLEASE!
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #8 of 10 (permalink) Old 12-01-2015, 02:30 PM Thread Starter
First Name: Kerry
After taking the advise offered and having read the pieces supplied by Sticks I can report the problem is solved.
Cleaned the collet and the bit shank and the slippage was no more.
Thanks gents
Kerry
-Walter Blodget
Larkan is offline
post #9 of 10 (permalink) Old 12-01-2015, 02:33 PM Thread Starter
First Name: Kerry
Thanks for that Reg. I'm looking into a Muscle chuck. I have great respect for routers and machinery in general and am very conscious of safety.
Kerry
-Walter Blodget
Larkan is offline
post #10 of 10 (permalink) Old 12-01-2015, 03:08 PM
Thanks gents
good to hear...
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 03:22 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Broken bit Mortice Router Bits - Types and Usage 3 02-20-2009 11:51 AM
