Freud bit question... by Moz... - Router Forums
 8Likes
post #1 of 12 (permalink) Old 12-10-2015, 01:00 AM Thread Starter
Default Freud bit question... by Moz...
@Moz ...
got this as a PM and thought it was better served on the Forum...
Okay, I want to get a 1/2" Shank 3/4" Straight & Mortising Router Bit for my Box Joint Beehive Project.
suggest you get a bit that has a slight spiral (down shear) to it and not one w/ a straight cutter....
and you don't want to have much more cut length/depth than you need...
Freud Tools | Mortising Bit
Here is a Freud on e-bay:
http://www.ebay.com/itm/181950556102...%3AMEBIDX%3AIT
this is a Diablo by Freud and their entry level...
see the PDF...
but for $5 less, I can get this one, which is longer, and has a trim bearing on it.
http://www.ebay.com/itm/400943513534...%3AMEBIDX%3AIT
this one ships from Hong Kong...
I'd suspect a knock off in a heart beat putting size, endurance and quality into question especially for that price....
If it is a knock off you own it, good or bad...
I know you like Freuds and recommend them often.
yup...
I have found better bits out of the box but only by a thin margin..
where the Freuds shine is their Customer Service, longevity and they are good to my bottom line as where replacements are needed more frequently for other brands...
now this is in a commercial shop...
you do realize that these bits you linked to are intended for different tasks..
But for a 'just starting out idjit' like me, would it make much difference one way or t'other, and should the trim bearing and addl. length be a consideration?
what ever...
Thank you for ALL your guidance, advice, and links. You have been SO helpful, just in getting me past my fear of the router table.
no problem...
~M
post #2 of 12 (permalink) Old 12-10-2015, 01:13 AM
"But for a 'just starting out idjit' like me, would it make much difference one way or t'other, and should the trim bearing and addl. length be a consideration?
what ever..."
-Moz
Moz; I've posted this 'bit' in the past:
DaninVan is offline
post #3 of 12 (permalink) Old 12-10-2015, 01:26 AM Thread Starter
what ever..."
-Moz
good one Dan...
post #4 of 12 (permalink) Old 12-10-2015, 01:30 AM
Default Gigo
...it be-hoofs-me to add my 2-sense worth!
billyjim and schnewj like this.
DaninVan is offline
post #5 of 12 (permalink) Old 12-10-2015, 01:32 AM Thread Starter
that's cherry..
post #6 of 12 (permalink) Old 12-10-2015, 01:40 AM
Moz here is a link to a Fine Woodworking router bit test that was done in '07. I don't think a lot has changed since then except for some newer manufacturers that weren't around when the test was done. The method used in the test was fairly sound from a scientific point of view. http://www.whitesiderouterbits.com/T...RouterBits.pdf
The longer a bit is the more it will chatter and vibrate in the cut so you will get a smoother result by using the shortest bit that will get the job done, plus shorter usually means a little cheaper. Avoid the chinese bits off ebay, there may not be the quality control there should be. Although there are bits made in China that are good and those are sold by reputable companies and the factories use quality materials, quality machinery, and have good QC. The very best are still Whiteside's made in North Carolina though.
post #7 of 12 (permalink) Old 12-10-2015, 02:43 AM
Moz
Moz's Avatar
First Name: Moz
Send a message via Yahoo to Moz
Does the number of flutes make a difference? I see single, double, and triple flutes.
I would assume 3 must be a very smooth shave like those Gilette razors.
But is one really crude if sharp?
~M
Heaven help you all. I am a wordy thing, long in love with the how and why behind almost everything...
Moz is offline
post #8 of 12 (permalink) Old 12-10-2015, 02:55 AM Thread Starter
more is smother...
one is prone to chatter if the feed rate is too fast...
less cutters cost less...
post #9 of 12 (permalink) Old 12-10-2015, 03:06 AM
Moz
Moz's Avatar
First Name: Moz
Dan, there is a saying I would hear Master Carpenters say on jobsites:"Good, Fast, Cheap. Pick any 2."
I guess that applies to router bits, too, huh?
~M
DaninVan likes this.
Moz is offline
post #10 of 12 (permalink) Old 12-10-2015, 08:41 AM
I like that saying, Moz!
old coasty likes this.
DaninVan is offline
Newb. Question - broken router bit oilman87 Table-mounted Routing 23 05-19-2014 04:39 PM
3/8" Osrud bit question, grrrrrrrrr dask Router Bits - Types and Usage 5 02-29-2012 11:44 PM
Question about rabbeting bit sets LBrandt Router Bits - Types and Usage 2 07-19-2009 05:07 PM
Harsh question about a router bit Greeneyedeagle Router Bits - Types and Usage 13 03-25-2009 05:19 PM
Router Bit coating Question Bob N Router Bits - Types and Usage 11 12-04-2004 06:39 PM
